Question about Canon PIXMA MP530 All-In-One InkJet Printer
I found a cardboard disc cover stuck in the paper loader and removed it but now i get printer not responding Regards Ron Tipping
  • 4,323 Answers
Hi
Please turn off the printer and unplug it frrom mains. Inspect the ribbon cable attached to the carriage, check if it is loose or disconnected. If the ribbon cable is fine then clean the printer from inside and restart the printer. Now check if you are able to print. If not then please tell me what error you are getting on screen or on the printer.
Thanks
Daniel
Posted on Aug 23, 2010
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
Canon pixma mp495 error
Solution 2 is correct there is either a paper jam, or somthing obstructing the print path. First check to make sure you don't see no paper jamed, if not look in were you would put the paper to see anything that may have fallen that is causing jam, gentel turn printer side to side to see if u see hear or see anything moving around. If u see nothing then somthing has surly has fallen in printer has gotten stuck in printer rollers more then likly. To find out what's stuck find a piece of thin cardboard, I used the front cover of my phonebook and push cardbord through printer and what ever is jamimg the paper should pop out on the other side. In my case it was a flower seed and I was able to use twizzer to remove and issue was resolved. Printer is working fine
Feb 25, 2012 | Canon Office Equipment & Supplies
I have a piece of paper stuck in the top of my hp 1012 printer and I cannot get at the area where the paper is.
Follow these steps to remove jammed paper from the printer
1.Open the print cartridge door, and then remove the print cartridge.
NOTE:  Opening the print cartridge door and removing the print cartridge relieves tension on the product rollers, which prevents damage to the product and makes the removal of jammed pages easier.
Figure 1: Open the print cartridge door and remove the print cartridge
CAUTION:  To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
2.With both hands, grasp the paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
Figure 2: Remove the jammed paper
3.Look inside the product for any torn pieces of paper or labels, and then remove them.
4.If any jammed paper remains in the input tray or the output tray, grasp it with both hands and gently remove it.
5.Reinstall the print cartridge, and then close the print cartridge door.
Figure 3: Reinstall print cartridge and close print cartridge door
1.Press the Power switch to turn off the product.
2.Wait 30 seconds, and then press the Power switch to turn on the product.
Happy printing.
Regards,
Shrey
Jun 02, 2011 | Office Equipment & Supplies
Problem with paper feed. frequent message: carriage jam, open top. No apparent jams, cleaned rollers, slider bar, etc, problem persists
Open the Rear Access Door,
Clean the rollers ( upwards ) with a lint free cloth ( little damped in water )
Close the Door
Open the Front access door, Check if there are any paper pieces stuck,
Remove the cartridges out and Install back.
Close the Door and turn on the printer.
It should work.
Regards,
Ron
Feb 22, 2011 | HP PSC 1610 All-In-One InkJet Printer
XEROX ERROR CODE 09,008,43:10249 PLEASE HELP
What that normally means is you have one or more ink stucks not sliding down the ink loader properly.
Check to see if you have one or more ink sticks not moving freely in the loader. That is what that code means.
Here is the manual information.
  1. Remove any paper from the Output Tray.
  2. Raise the ink loader Top Cover to access the ink stick bins.
  3. Make sure the Ink Sticks are able to freely slide down the bin.
    CAUTION: Do not force an Ink Stick down the loading bin.
  4. Close the Top Cover.
Feb 05, 2009 | Xerox Phaser 8500/DN Printer
Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Jan 18, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Brother HL 2040 - Notecard sized paper jam (you responded)
Access cover is the cover where open to replace the cartridges , once you open that check for any paper stuck ....if still cant find carry with envelope procedure in the troubleshooting steps given earlier , Its place were we are ready to help people ......
Good luck....
Nov 26, 2008 | Brother HL-2040 Laser Printer
Cannon MP210 printer
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
Jan 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
19 people viewed this question
old marine
old marine
