Question about Kenmore Washing Machines
Generic problem for all Washing Machines Kenmore Series 70 Washing Machine - won't drain water
  • 176 Answers
Check the water bumb
can you do that
meby som theng is close
Posted on Aug 23, 2010
My washing machine does not spin and drain?
Why won my washer spin or drain Kenmore 110 Series Washing Machine
Since you gave no make or model info I can only give general "GENERIC" causes.
Feb 21, 2017 | Washing Machines
How do i determine if my switch is working on my kenmore 70 series washing machine
i think there is some problem in wiring of spin and drain. thats y it works only for washing. current stops after washing. or otherwise click below link and check the manual may be its timer problem
http://www.askmehelpdesk.com/appliances/kenmore-washing-machine-70-series-repair-manual-479481.html
http://www.askmehelpdesk.com/appliances/kenmore-series-70-washer-manual-445690.html
Jan 04, 2012 | Kenmore Washing Machines
How do you replace the lid switch on a Kenmore 70 series washing machine
Hi.
Check for drain blockage at the filter. Check setting of drain hose at the back. If there is no drain problem check pressure switch, central control unit and pump motor.
Here a tip talking about drain and spin problems: http://www.fixya.com/support/r7775926-no_spin_tip_all_washers
Nov 13, 2011 | Kenmore Washing Machines
Kenmore washer series 70 wouldnot drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 23, 2011 | Kenmore Washing Machines
My kenmore series 70 washing machine is leaking water from under the front of the machine. i've checked the drain hose and it seems to be OK. what else should i check
http://appliancejunk.com/forums/index.php?topic=5191.0
Use the link above to access the drain pump. It is the cause of your leak.
Nov 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
Kenmore series 70 will not fill
Ive only run across this a couple of times in my years of appliance repair. This sounds like you do not have an air gap on the drain hose. Where the hose hangs into the wall drain pipe make sure you do not have that sealed air tight with duct tape around it or something. It needs to have a gap all the way around the hose and just hang freely. If it is sealed off then it creates a siphon effect and sucks the water right out of the washer tub into the drain.. Hope this helps.. Thanks
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Washing Machines Logo
95 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
