Question about Fujitsu Siemens AMILO Pro V1000 Notebook
Hi The ''N'' key has flipped dout of my keyboard and I cannot get it back ,,,I fear the key attachemt is broken. Is there anyway of fixing or finding a replacent key?
    President:
  • 2,666 Answers
A fiddly job to do but is possible. The key that has come off will have a clip attachment underneath, you need to remove it and fit it to the clips on the keyboard first. It will be in an X configuration so you need 2 very small screwdrivers (jewellers ones work well) to lift the "X" once connected to the keyboard and connect to one side of the key button.Once done on one side remove the screwdrivers and press down on the key button to click the other side in place.
I can't think of a better way to describe it. One of those " easy if you know how" things.
Posted on Aug 23, 2010
How can I fix a broken key? A cat drop something onto my keyboard and a key popped off. It just floats there and I can't get it back in place.
There are 3 different types of key fixing, can you let me know the model number and I will be able to offer you some ideas.
Sep 20, 2015 | Yamaha Portable Keyboard
Tip
How to Fix an Acer Laptop Keyboard Key
<ol> <li> Power off the Acer laptop and flip the unit over. Slide the battery release lever over and lift the battery out of the laptop.<br /> </li> <li> Turn the laptop back over and open the lid. Look inside the open area on the keyboard where the key would normally go. Check to see if the plastic retaining clip is still inside the hole.<br /> </li> <li> Locate the plastic retaining clip if it fell off the keyboard along with the key. Use a pair of tweezers to set the clip back inside the hole. Line up the holes on the clip with the four raised nodules inside the keyboard hole.<br /> </li> <li> Set the key back onto the plastic clip. Push the key down until it clicks into place.<br /> </li> <li> Flip the laptop back over if there are keys that are not working properly. Use the Phillips-head screwdriver to remove the three screws on the left side of the case that hold the keyboard in place. Turn the laptop back over so that you can see the LCD screen.<br /> </li> <li> Push the thin end of a flat-head screwdriver under the LED indicator strip above the keyboard. Pop the strip upward and pull it off the laptop.<br /> </li> <li> Lift the keyboard up towards you until the long ribbon cable running from the bottom of the keyboard to the motherboard comes into view. Unplug the cable from the port on the motherboard and then pull the keyboard and its ribbon cable off the case. Spray out the underside of the keys and the inside of the Acer laptop case with canned air.<br /> </li> <li> Reassemble the keyboard, LED indicator strip and battery.<br /></li></ol> If I could be of further assistance, let me know. <br /> <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 06, 2011 | Acer Aspire 5500 5570-2609 Laptop
The sapcebar had poped off and all the parts are still fine and arent missing or broken is there anyway that I can fix it without bringing my computer back to get it fixed?
Just place the space bar back on the keyboard, align it in its correct position and push down on the space bar key until it clicks in place.
Dec 24, 2010 | Computers & Internet
I have to keys that came off my keyboard is there anyway to fix em?
If the plastic/hinges/clips are still on the keyboard, then place the key back on the keyboard, line it up with the other keys and press down on the key until it clicks in place.
Nov 24, 2010 | Computers & Internet
How to replace a key that popped off
Ichand1958 is right, if its broken the no matter what you do it will not go on, but if he thinks installing a key is difficult, how you think the average user will be able to take apart the entire laptop to install a keyboard?? I think you should first try just fixing the key, often the new key will just snap right on. Have a look at http://www.individualkeys.com/ACER_KEYS/ and if that does not help, THEN take the laptop to a shop and have them install the ENTIRE keyboard.
Jan 25, 2010 | Acer NSK8458AN Keyboard
Gateway notebook , broken key on keyboard
If you are able to, try and pop the key out of the keyboard with a flat-head screwdriver. Here's a guide on a generic Gateway. If there's no room in-between the keys, flip the computer off (while it's off) and see if there's screws in the back. This method concerns replacing the whole keyboard, and I'm not completely certain about how to do it. I'm sure google would help you out there.
Jan 05, 2010 | Gateway M-7301u Notebook
Some keys of my compaq M2000 dont function
Here's the FULL service manual.
http://h10032.www1.hp.com/ctg/Manual/c00312740.pdf
Hope this helps.
Please don't forget to rate my solution FixYa
Thanks!
Mar 02, 2009 | Compaq Presario M2000 Notebook
A key
If you've broken a key off the keyboard, you normally replace the keyboard
They are about $20 on average on Ebay
Jan 12, 2009 | Dell Inspiron E1505 Notebook
KEYBOARD CHANGED MONITOR VIEW TO HORIZONTAL... NEED FIX
Try hitting "CTRL + ALT + An arrow key"
That should flip you right back!
Oct 03, 2008 | Logitech 967437-0403 Keyboard
Keyboard comma come off
First exam if the retainer clip have any missing legs, and the hooks in the back of the key cover are not bent or broken. If Any of the parts are broken, no matter what you do, you will not be able to put it back on. See the following link for more info, and if it is broken, I have found the individualkeys.com to be very reliable source for replacement laptop keys. Hope this has been helpful.
http://laptop-keyboard-key.blogspot.com/2009/12/replacement-laptop-key-install-guide-1.html
Oct 03, 2008 | ASUS 90-A4C1K1000 Keyboard
Fujitsu Siemens AMILO Pro V1000 Notebook Logo
186 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
