Question about Electrical Supplies
How do you remove the rotor from a Sears Craftsman 3600 watt generator model no. 580.323602?
    Problem Solver:
  • 10 Answers
The rotor is attached to the crank via taperlock. You must remove the rotor bolt which goes thru the rear bearing. Then take a 3 LB. rubber or deadblow hammer and sharply strike the rotor on the laminations. not the winding. You usually have to do this several times from both sides before it breaks the taperlock free, Use force behind your hammer swing, It will eventually come off. Have patience.
Posted on Aug 31, 2010
Maunual for generator #580.32670
How do you replace the cam in the motor of a craftsman model 580327360
Nov 06, 2013 | Craftsman Briggs & Stratton Generator,...
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
High idle
most cheaper generators do not have a idle kick down and are made to run at 1850 rpm's the older ones run at 3600 rpm if it has a no load idle system there will be a switch
Aug 27, 2012 | Craftsman 5600 watt Generator
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
Have a portacable generator. model BS1550 w Runs
Breakers could be bad, but no power to all the plugs, including the 240vac plug indicates something else going on. Either residual magnetism has been lost (has it been a while since it been ran?) and needs to be flashed, capacitor or diodes in regulator are bad, or there has been damage to the rotor or stator. There could also be a problem with the brushes on the rotor as well.
Also, if engine is turning too slow, the alternator may not kick in as well. Make sure that you are turning either 1800 or 3600 RPM, though it is a little hard to do this without electrical output. You might try playing with the governor while a lamp with a sacrificial incandescent bulb is in it. If the engine speeds up, and the bulb lights, then governor needs to be adjusted.
Jul 16, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Electrical Supplies Logo
124 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
