Question about Malber WD1000 Front Load Washer/Dryer
Loose Wheel and Leak
I have two problems with my Malber WD1000.
1. The nut on the wheel is loose. Every time I tighten, it just loosens up again. Any suggestions? Should I get new nut. Any idea where to get one?
2. Second problem... Sometimes during the spin cycle soapy water is leaking out somewhere close to the front right of the machine. I checked the hoses and could not find any holes or loose connections. This does not happen every time, usually with larger loads. Any idea on what the cause is or how to fix it?
  • alorenburg Jul 06, 2008
    During the spin cycle soapy water is leaking out somewhere close to the front right of the machine. I checked the hoses and could not find any holes or loose connections. Any idea on what the cause is or how to fix it?
  • 3 Answers
1 no just take the nut off and put a lock washer ingetween it
2 your using to much detergent
Posted on Sep 15, 2008
Sometimes my truck start will not start but if I turn the key off and wait for ten minutes and try again it will start.
I have had this same issue with both my personal truck and MANY customers cars. Every time, it was something different. Ignition Module, Immoblizer, Corrosion on the Battery, Loose Wire on the Starter, Neutral Safety Switch and Key... ... You need to troubleshoot it while it is not working.
Mar 14, 2015 | 2005 GMC Canyon
Can you adjust the tension on the wheel?
What sort of tension?
Rim loose on spokes: evenly tighten the spokes to add tension ( very high skill required to keep the rim true. Pro help should be sought)
Too much wheel side play: tighten the wheel to frame axle bolt (unless the bearing is gone, then you'll need new hub bearings).
Chain tension too loose: Move the rear wheel away from the pedals by loosening the axle bolt, pulling back to remove most (but not all) or the slack from the chain. Pay attention to the alignment of the wheel in the frame. Tighten the nuts back down
Feb 17, 2015 | Cycling
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
How do I tighten the nuts on my bench grinder?
A bench grinder has left handed threads on one shaft and right handed on the other,so that the grinding stones don't unscrew the nut as you grind something.I haven't ever gotten around to getting a bench grinder,but on my father's, I used to just hand tighten the nut,then grab the grinding wheel with my hand while tightening the nut with a wrench.(You don't have to make it real tight,as the wheel pushing against the nut will keep it tight)
May 04, 2012 | Heating & Cooling
I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Feb 18, 2011 | Schwinn Original Airdyne
Sterring colum is very loose on my chevy s 10 blazer overall steering feels good just steering wheel is loose
LOOk on the top of the steering box in the middle there is a stud with a nut threaded onto it this is the adjustmemt for steering wheel play . Loosen the nut and take a stright head screw driver put it in the slot in the stud and turn it in . rembember you should have an inch or so free play in the steering wheel this will tighten it up then tighten the nut back down
Feb 15, 2011 | Chevrolet Chevy Cars & Trucks
If wheel lug nuts are not torque'd properly how long would it take for them to loosen and fall off, in mileage?
First it would depend on how much they were torqued and the road conditions.The driver side lugs would loosen up first since the lugs turn left to loosen as the car moves forward the lugs will come loose where as the passenger side would tighten a little on there own since moving forward turns the lugs to the right causing them to tighten.If the lugs do come loose your car will start vibrating real bad.It would probably take no more than about 10 to 15 miles like I said depending on road conditions and speed.
Feb 09, 2011 | Wagner BD61355 Wheel Lug Nut
Cant take the wheel off
Spray the base of the lug nuts liberally with penetrating lubricant and let it sit overnight. Break the nuts loose with a lug wrench or a breaker bar -do not jack the car up yet. Break the nuts loose while all 4 tires are on the ground with the full weight of the car on them. Jack the car up once they are loosened to remove the wheel. To reinstall the wheel, snug down the nuts with wheel off the ground, then drop the car on down completely and tighten the nuts to factory ratings
May 06, 2010 | 1999 Kia Sportage
Loose chain
Loosen the Back Nuts on the Side of the Rear Wheel, Then use a Wrench to Turn the Bolts extending out the Rear of the Bike in Clockwise to pull the Rear Wheel Back, Thus Tacking Slack out of the Chain. Do Not over Tighten as the CHain Tightens some itself with Flex when you put Weight on it. Retighten Axle Nut. Thats it.
Apr 25, 2009 | 2002 kawasaki VN 800 Vulcan Classic
Chainsaw chain came off/is loose
You need to tighten the chain, and or remove and reinstall the chain depending on whether or not it has come off the drive wheel. The chain drive is on the right hand side of the saw, and there are either two nuts (about 1/2 inch or 13mm) holding the chain on, or there is a little half round handle you can use to tighten the chain after it is on the drive wheel properly. The saws with the two nuts on them have a small flat blade screw on the backside on the bar that you tighten the chain with. And to make things more confusing, some of the newer bars have a round hole in them, that after you loosen the two bolts, you stick a screwdriver in the hole and turn it clockwise to tighten the bar, then you re tighten the 2 nuts.
Since from your description that it wont engage to cut, you will have to remove and reinstall the chain since it is loose from the drive wheel. Clean out all the wood chips, etc in the drive wheel area before you reinstall the chain, make sure it is not on backwards and sharpen and oil it before you use it. Rick
Apr 11, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
102 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
