I just bought a canon LBP5050 and found that it can't use with my apple airport extreme for printing wirelessly. besides that, it always need to do the calibration and the noise is irritating. Hope you can solve my problem.
4 Suggested Answers
jonags3
  • 83 Answers
SOURCE: Is the Pixma MX310 compatible with Apple's Airport Extreme?
Try to check your cable connection maybe its properly inserted in your port. If it continues to appear try reinstalling your printer. When installing follow the steps in the installation. Disconnect the usb cable to the PC prior to installation. You will be ask to attached it to the PC during installation before completing the installation. Check also your network settings maybe some plug ins are disconnected. After installation it needs also to restart the pc so that new changes of the settings will be detected.
Please rate this solution so that I will have more bases to suggest if you will elaborate on the result.
thank you.
Posted on Nov 28, 2008
old marine
  • 2147 Answers
SOURCE: can not get my MX310
The MX310 is not a wireless printer. You must use a USB cable from the computer to the printer to print.
Posted on Mar 06, 2010
SOURCE: MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Posted on May 19, 2010
Blinking white light on apple airport extreme
Continual white blinks on Apple gear means an update failed, a resort is required, or the init test did not pass
Apr 03, 2012 | Apple AirPort Extreme (AIRPORTEXTREME)...
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Can not get my MX310 to work on the wireless network using apple airport extreme and mac
Mar 06, 2010 | Canon PIXMA MX310 All-In-One Printer
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Where can i download the AirPort Extreme wireless networking
Dear,
Kindly find the AirPort Extreme driver at this location.
Regards,
Have a good day.
W.
Mar 19, 2009 | Apple AirPort Extreme (AIRPORTEXTREME)...
Reply: What wireless card does your macbook have?
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x168C, 0x86)
Wireless Card Locale: USA
Wireless Card Firmware Version: 1.4.8.0
this info can be found in apple/about this mac/more info/system profile/airport card
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
266 people viewed this question
k24674
jasbo
jasbo
