Question about Epson Stylus Photo R1800 InkJet Printer
I cannot match the print color with monitor color. I've tried everything. Downloaded new drivers, tried various combinations within Photoshop. reclaibrated my monitor. Going nuts. It used to work, but now it doesn't. I have a Stylus R1800 and an iMac Intel.
    President:
  • 2,678 Answers
Not an uncommon problem. Monitors are normally adjusted to what the viewer considers the ideal FOR THEIR viewing which has not relation to what the image is actuall like-hence the mismatch in what you see and what the print looks like.
Have a read here and see if it works.
http://www.northlight-images.co.uk/viewing.html
Posted on Aug 23, 2010
Gray color prints as brown using Photoshop CS6
check your image mode.. click image, then mode, then cmyk color.
Sep 23, 2017 | Epson Stylus Office T1100
My color photos print darker then they appear on my monitor. I use Huey pro to callibrate, I use photoshop and print to an Epson 3880, using the Epson supplied profiles. I turn off printer management and...
You need to select the correct Printer Profile for the type of paper you are using. If you are using non-Epson paper, you need to download the ICC Profile from the paper mfg. website.
You also need to check if the paper is comparable to an Epson paper that the printer supports. If the paper your using is not comparable to any Epson paper the printer supports then you might want to try using another kind of paper. Epson prefers Epson Paper. You can also try any non-Epson paper as long as it is comparable to any Epson paper the printer supports. Try to go to their website and look at the printer's specifications. It lists all type of paper the printer supports.
Jan 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
Wont print out accurate color when printing a Greyscale photo
Hi, I recommend doing a nozzle check first to ensure all the colours are printing fine.
Within the advanced option of the printer driver you have an option to select greyscale, it might be worth enabling this feature.
If you are using glossy media the problem might be down to the ink reaction with the glossy resin as this can cause casting or bronzing. To check this try printing on matt paper.
If you are printing from Photoshop check your colour matching settings, the easiest way to do this without messing to much is try printing from another application, I would recommend Epson's own, Easy Photo Print.
Dec 04, 2009 | Epson Stylus Photo R200 InkJet Printer
I am the Graphic Artist and Printer for a public library. We have a logo that has the Pantone color PMS 375 green in it. I mix my own inks and have no problem reproducing the color properly on a printing...
Laser printers, although they have a larger color gamut than a CMYK offset press, still will not be able to reproduce a majority of Pantone special colors.
Professional inkjet printers, especially those using more than 4 inks, are far better at this - the ink pigments are more color-pure and concentrated than those in laser toners.
Remember, that Windows print drivers work in RGB, and use ICC profiles to convert color data to CMYK components for printer. If you have a CMYK file, and look at it on your monitor, it's converted (using monitor ICC profile) to monitor's RGB colorspace, and then back to CMYK with the printer ICC profile when printed. Converted twice with ICC, which always introduces distortions...
If you have a properly calibrated monitor, and a good printer profile installed, you have better chances of reproducing screen colors on the printer, especially if you work in RGB.
As a simple, but laborious solution, I would suggest preparing "swatch sheets" yourself using some graphics software. Preferrably in RGB, not CMYK. A series of gradients with the green component going from, say, half way to maximum, and other components in various combinations, like R0 B0, R10 B0, R20 B0,... then R0 B10, R10 B10, R20 B10... and so on. Print those, and try to find a spot in the gradients that is the closest to your color sample, and then make swatches with smaller increments around that color to find the best RGB combination.
Good luck :)
Nov 13, 2009 | HP Color LaserJet 5550hdn Printer
The printer does not prints exactly the colors that I see in my tft monitor.it seems that the printer adds a bownish filter in my images and prints them more dark-brownish. I print using ACDSee. I also...
Check your inks, especially the yellow, a bad printhead will allow the colors to cross contaminate. Usually yellow looks a brown color in the cartridge. You need to install a new printhead and toss any contaminated inks.
Jun 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Trying to match color between photograph on monitor to printer. OS is Vista.
The only way to get color matching with the solid ink line 8400, 8500, 8550, 8560, 8860. Is to build you own colors with the CMYK sampler printout.
Beware this will print over 50 pages of swatchs showing the mix of CMYK for various colors. Your can then look at the color you want and see how it's made up i.e. 30% 30% 40% yellow gives a orangish color. You can then build these colors and name them in your application.
You will NOT get Panotone color matching with the solid ink series.
Apr 27, 2009 | Xerox Phaser 8560DN Laser Printer
Color prints yield only brown.
do the pictures look right on the monitor?
a program that comes with Photoshop is called adobe gamma, and it starts the first time you run photoshop needs to be configured. try that as well
also try in microsoft word , to color some text and print it, does it print in the correct colors??
if nothing works, try reinstalling the printer driver, maybe you have chosen the wrong driver.
tell me what you get.
Mar 26, 2009 | Canon MX300 Office All-In-One Printer
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
66 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
