Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
Transmission stuck. Back wheels slide instead of turning. In the air and one wheel turns one way and the other wheel turns in the other direction. Been sitting for a couple of years.
3 Suggested Answers
  • 86 Answers
SOURCE: rear wheels locked
To move tractor you can remove one of the back wheels and remove key in shaft then replace wheel you should be able to move it .
Posted on May 12, 2009
  • 6468 Answers
SOURCE: Changed battery and mower started with no problem. Cant get it to move though. Wheels wont turn. Lifted rear wheels off ground and they rotating in different directions??
there is a lever you move to push them around
Posted on Mar 23, 2012
Ignition switch will not turn
Which ever direction the wheels are turned when you shut it off will have to be turned that direction when you try to turn ignion to on. Have a helper turn the wheel while you try to turn the key. It will be hard to turn steering wheel because engine is not running. It is stuck against the steering wheel lock.
Aug 19, 2017 | Cars & Trucks
I have a 95 camaro, I put the key in ignition and it will not turn the ignition. It's like it's stuck. Replaced the ignition module and still cannot turn ignition. Help!
the ignition module (ignition switch on top of the steering column) normally doesn't get stuck.
things you can try:
steering wheel lock: (the pin gets a "burr" on it and locks everything up) wiggle steering wheel back and forth while trying to turn key.
transmission lock (parking on an incline will jam up the interlock)
push the shifter farther into park while trying to turn the key, or wiggle shifter
Sep 19, 2014 | 1995 Chevrolet Camaro
Craftsman GT3000 - After placing in gear, wheels don't turn
I think there is a safety or shear pin in the drive wheels and it probably needs replacing.They are inside the shaft and are put there so if you hit a stone or something the pin will break instead of breaking an expensive part.
Jan 27, 2018 | Craftsman Garden
The key is stuck in the ignition cant start. Thanks
Turn your steering wheel left or right side. If it moves, then good for you as the key will not be stuck anymore. But if doesn't, it probably means that locking system in the steering wheel is damaged. For this, you can just turn the steering wheel opposite to the direction of the car wheels. Most of the time, cars are turned off with the wheels turned on the opposite directions, which makes the key get stuck in the ignition due to pressure in the steering wheel. When the pressure is released from the steering column, a click can be heard and key is released.
If no luck, there might be a problem with shifter mechanism, which means that you have a trip to the repair shop in store for you. Get this problem addressed immediately, as it could mean that your shift interlock is out of order, which can increase the chances of deploying the air bag up in your face, causing a serious injury.
Dec 27, 2010 | 1994 Toyota Land Cruiser
Key ignition is stuck ans steering wheel as well
Turn your steering wheel left or right side. If it moves, then good for you. But if doesn't, it probably means that locking system in the steering wheel is damaged. For this, you can just turn the steering wheel opposite to the direction of the car wheels. Most of the time, cars are turned off with the wheels turned on the opposite directions, which makes the key get stuck in the ignition due to pressure in the steering wheel. When the pressure is released from the steering column, a click can be heard and key is released.
Dec 20, 2010 | 1998 Chrysler Sebring
Steering column wont turn ignition is stuck
Rock Steering Wheel Back and Fourth While Turning KEY.
Or If the Wheels are Turned HARD in one direction you mest Turn Steer Wheel in THAT Direction While Turning KEY
Dec 23, 2009 | 1998 Dodge Caravan
Shaft coming out of transmission that clutch basket slide upon..it this suppose to free wheel while transmission is in gear...please help this is on a big dog k-9 motorcycle..6 speed baker transmission
Without clutch plates installed. The clutch basket inner is directly connected to the tranny input shaft- if you turn the inner clutch basket while in gear it should drive the rear wheel. The outer basket should spin freely regardless of gear selection and have no affect on the tranny.
The input shaft of the tranny itself ( the shaft the clutch basket slides on) should not free wheel when in gear.
Dec 06, 2009 | 2001 Titan Gecko RM
2003 expedition replaced p/s pump and steering rack. it is still hard to initiate a turn in either direction regardless of speed
raise the truck up and turn the wheels left to right, you most likely have air in the lines.
Sep 28, 2009 | 2003 Ford Expedition
Rear wheels will not turn. Worked fine when stored for the winter
Craftsman-Husky...same tractors-built in the same factory. I also had a problem with the hydrostatic transmission not providing power to the rear wheels. Here's what Sears told me:
(1) Check to make sure the drive belt is tight both under the engine-and the tranny.
(2) Air can get into the hydrostatic transmissions-especially during shipping (new mower) and storage.
So.....
Pull your freewheel pin out to disengage the tranny-then push the mower both forward and then backwards for 50' or so. Then push the freewheel pin back in and start the mower. If the transmission then works-drive forward-then backward-then forward repeating the cycle about 4 times. Drive about 50' in each direction. This should purge the air from the treansmission.
Mar 20, 2009 | Craftsman Garden
Direction ofrd windstar 2003
look under hood and look at the steering gear box. Thats the thing at the end of the steering column. It has a fiber plate that takes the vibrating out of the steering column It may be about tore in half or hanging on by one bolt instead of two.
God Bless Greg
Jul 14, 2008 | 2003 Ford Windstar
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
