Question about GE WSXH208A Front Load Washer
Washer is making a banging noise when spinning, redistributed the load and got same results, legs are stable and even
  • GE Master
  • 17,130 Answers
It is possible that the dampers mounted to stabilise the drum on motion is defective. The suspension springs can be weak and aggravate the drum to aggitate out of balance.
So check from the underside for the dampers, replace if soft and test.
Posted on Aug 23, 2010
Machine in banging the sides of unit, as well as making a crunch noise
Too many clothes loaded makes it spin out of balance.
Remove some clothes or try redistributing the load. In the future do not add so many clothes.
Oct 01, 2017 | Washing Machines
Kenmore elite will not finish a wash. every load no matter the size has a UE code. Please advise.
the ue code indicates that the control detects an unbalanced load in the washer that cannot be redistributed. press the start/pause button and try to redistribute the load. here are some problems that can cause this error code
the washer is not level or not stable. make sure that the washer is leveled properly front to back and side to side. press down on opposing corners to make sure that all 4 feet are firmly on the floor. adjust the leveling legs if necessary.
WASHING TO SMALL A LOAD
laundry can sometimes gather to one side. redistributing the load manually can resolve this issue.
try running the washer without any items added and see if it will spin properly. if not, you could have a problem with the control board or the hall sensor on the motor that detects motor speed.
uE error code 79631512210 Kenmore Elite Washe
May 17, 2015 | Kenmore Washing Machines
Frigidare Gltf1040as0
Good Afternoon Carrie,
I understand that you are hearing a loud noise in the spin cycle as well as water leaking from your Frigidaire washer, model# GLTF1040AS0.
You will commonly hear a high pitched "jet engine" noise during the spin cycle. If you are hearing a vibrating noise, it could be your washer is not resting firmly on the floor. With this you will adjust the leveling legs so the washer is level. If after leveling your washer you are still receiving a vibrating sound, you might want to redistribute the wash load inside your appliance.
If after you redistribute the wash load, you are still hearing a loud noise in the spin cycle, I suggest contacting a local authorized technician.
For the leak I recommend contacting a technician. This way they are able to find where the leak might be coming from and repair it before there is any damage done to your appliance. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire Washing Machines
Ds codemkeeps coming up even though the door is shut
The "dc" error code indicates an unbalanced load is preventing your washer from spinning properly. Try redistributing the load, then press the Start/Pause button. If the load appears well-distributed, you may need to make adjustments to the leveling legs to make sure the washer is properly leveled, removing the clothes and running a spin only cycle to make the necessary adjustments. Once firmly leveled, be sure the plastic leg locks are tightened to prevent them from vibrating loose.
Apr 14, 2014 | Samsung WF337AA Front Load Washer
Washing machine makes banging noise when washing
This usually means the clothes are not loaded evenly. Try redistributing them and see if that helps
Sep 08, 2012 | GE G.e. Gtwn4950lws He Top Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER MAKES A BANGING NOISE WHEN SPINNING
Try redistributing the wet clothes for better 'balance'.
Jan 08, 2009 | Whirlpool LHW0050PQ Front Load Washer
GE WSXH208A Front Load Washer Logo
135 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
