Question about Maytag Dryers
Maytag Legacy Gas Dryer MGD5770TQ0. Turn timing knob to any setting whether minutes or cycle. Dryer runs properly but knob does not move. Dryer does not stop until door is opened or knob manually moved to stop. Is the problem in the timer or should we be looking at something else
  • gaylesutton Aug 23, 2010
    we can hear the timer motor ticking. could a gear be stripped?
    or if we're hearing the motor is it just not working properly?
  • Maytag Master
  • 8,220 Answers
I looked over your model number and saw what I thought I would find: moisture sensorsMaytag Legacy Gas Dryer MGD5770TQ0. - 2415f22.jpget clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely. Yank this DUDE out of its slot and clean the contacts. Re-install. Retry.
Posted on Aug 24, 2010
    President:
  • 1,554 Answers
The problem is definitely the timer particularly the timer motor not working. You can verify it by connecting a 120 VAC supply to the timer motor terminals. Replace the timer (part number 8566184) and it should address the problem.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 23, 2010
  • Jahn27
    Jahn27 Aug 23, 2010
    The gears are stripped if you hear a ticking sound. In either case, you have to replace the timer because it is not repairable.
    okay, thanks. will do.
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Timmer Maytag Commercial Dryer
the maytag timer for MDE10 should be a multi vertical slide in type. If so under the keyed panel on the top of the dryer, is an electric control with a grey knurled knob facing the front of the machine.
This grey knurled knob is the time set.
The knob rotates clockwise (from front) under motor control while the dryer is running, and jumps back to starting position under spring control when the slide is pushed in.
There is a single grey stud moulded into the front of the knob, that is the sixty minute mark, and a number of slots before the stud, that take a nylon peg. they are 6 minutes apart 54 48 42 36 30 minutes. Inserting a nylon peg in the slot at 30 minute will do what you want.
Most service guys drop the peg in the bottom of the control when they remove it, makes it easier to find, next time, so if there is not a peg in any slot, examine the floor if the enclosure, A short nut n bolt will accomplish the same result if the peg is not there.
If the original multicoin push in has been replaced with a newer single slot device I dont know how the change is made, none of my dryers are that new.
Feb 24, 2008 | Maytag MDE16CS Electric Dryer
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
240 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
