Question about Royal PX1000MX Shredder
I can't get the door open do empty the shredding
    Genius:
  • 1,218 Answers
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Posted on Aug 29, 2010
Testimonial: "tks for the info you are correct to much shredding in the bin, but i did manage to open it and empty it, now i know not to overload it tks again."
  • gwtobey Sep 12, 2010
    How did you finally get it open? Mine is stuck
Another idea is to work it open enough to get the crevice tool for the vacuum cleaner in there. Remove as much at the front as possible. Use a fork to loosen up paper and work it ford and vacuum. Keep repeating until the bin can be removed. The vacuum helps with clean up but keep a box or bag ready to dump most of the paper in. Also empty before paper becomes packed down.
Posted on Nov 05, 2014
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Embassy shredder open door light won't go off after emptying bin. Therefore no shredding
The shredder probably has some kind of switch or sensor that detects that the bin is in its correct installed position. The interlock may be broken or blocked by paper shreds. An inspection inside the bin recess may reveal the cause so that it can be corrected.
Oct 19, 2014 | Office Equipment & Supplies
Door open button is lite. How do I solve this issue.
Sometimes debris can gets in the way of the sensor that tells the shredder it is safe to shred. Empty the shredder completely and see if the lite is still lit.
May 29, 2014 | Staples Office Equipment & Supplies
We missed emptying out the machine, now we are not able to open the drawer. What can we do?
Try shaking the machine to lower the cuttings in the bin. You might have to pull really ******* the bin to remove it. Be careful you do not break handle on the bin. The machine should have stopped shredding when the bin full sensors were activated, if they did not , then you have bad sensors in the unit and they should be replaced.
Aug 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Fellowes S8-95C is full, but can't get it open. Help!
I was able to pull really hard and open the bin 1-2". I turned the unit on its side over the trash can and some shreds came out. I alternated shoving a sturdy metal rod inside (first an aluminum architectural ruler then the longer handle of a squeeze clamp) to loosen up the shreds and tipping the machine on its side to get some loose shreds out. After doing this enough times I was able to dislodge the dense clumps and remove the drawer. Now that the machine is empty there is a red light on and it does not shred.....UPDATE: turns out somewhere along this rough process (paper was in rock solid clumps) a small piece of the door that presses the "door closed" switch broke off. Jammed a piece of cardboard in there and it shreds again, although it does not automatically turn off when the door is open.
Jun 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Shredder keeps turning off and full light comes on but its empty. Have to keep opening and closing door to shred something
Door switch possibly bad I am a shredder tech out of colorado. Call fellows at 800-955-0959
May 05, 2010 | Fellowes DM15C Shredder
Shredder screen reads door open even if the door is closed and wont let me do any shredding
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
Apr 25, 2010 | Universal Office UNV-38016 Shredder
The drawer to the shredder will not pull open
You have to get the drawer out to get to the screws holding the top on.
May 07, 2009 | Fellowes Powershred 120C-2 Shredder
Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
Royal PX1000MX Shredder Logo
974 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
