Question about HP OfficeJet D135 All-In-One InkJet Printer
I have an HP j6480, it has the "out of paper error", which is not the case. I have been through all the HP tasks for correction of this issue, with no success. I have heard the printer itself is flawed as I have seen multiple people online with the same error unresolved. Do you know a solution?
SOURCE: HP Printer D7260 Printer error
i do not have areason for why the printer continuously goes offline but there is a way to put it temporarily back online. Go to printers in the control panel. right click on d7260 and click on use printer online. This only seems to work for one or two docs before you have to repeat the process.
Posted on Mar 15, 2009
SOURCE: HP J6480 error message insert 'solution center disk'
When you get this error message again, insert the installation disc you used for the printer set-up. Then, click on "browse" and go to D:\Setup\SolutionCenter (D: denotes the drive letter of your DVD drive), and you'll find solutioncenter.msi there. Select it, and then click on "OK" ...it should then repair the installation and the issue should be resolved.
Posted on Mar 25, 2009
laxmankumar
  • 191 Answers
SOURCE: HP Office Jet J6480
HI,
Follow the steps to refrsh the USB connection which will resolve your problem.
=== Refresh USB Devices ===
1. Right-click My Computer icon on the desktop, and then select
Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click 'OK' to confirm the removal of the device.
NOTE: Repeat steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the
computer restarts, a "Windows has detected new or added hardware" message window will open.
Posted on May 23, 2009
  • 169 Answers
SOURCE: I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
  • 685 Answers
SOURCE: HP J6480
Try this...
Posted on Oct 28, 2009
Have a false paper jam on my HP all-in-one J6400 series printer
look here
http://h30434.www3.hp.com/t5/Other-Printing-Questions/HP-OfficeJet-J6480-false-paper-jam-error/td-p/12759
Apr 04, 2014 | HP Officejet J6400 series
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
HP J6480 paper jam but cannot fix
Usually when you see this it means there is either a tiny sliver of paper in there being detected or the paper jam sensor itself is the problem. If you open it up and follow the path the paper takes through you may find the piece of paper or spec of dust that is causing it. If you use a soft brush and a vacuum you can get everything out that might be causing this. The cause can be a pretty small spec of dust or paper. Usually if the sensor is bad there will be an error code so I would bet on the dust. If it is the sensor check for replacement cost of the printer verses cost of the sensor. Usually you can just buy a new printer as cheap.
Oct 22, 2009 | HP Office Equipment & Supplies
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90764
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3635378&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&lang=en&cc=us
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
I HAVE A HP OFFICEJET J6480 ALL IN ONE. THE PROBLEM IS THAT IT SAYS I HAVE A PAPER JAM. I HAVE CLEARED ANY JAM, BUT IT WON'T CLEAR OUT
Hp printer paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Aug 17, 2009 | Office Equipment & Supplies
Error is fax full cannot send or receive. Please help !! Hp J6480
I have not found the answer to this in the manual however, you may solve the problem in the following steps:
1. From the Setup menu, choose #6 Tools
2. Choose #6 Clear fax log
Problem solved! Hope you found this answer helpful.
sg
Feb 18, 2009 | Digital Products Hewlett Packard OfficeJet...
J6480 WILL NOT PRINT
Please click on teh follwoing link and download the software and run it, it would automatically fix the issue,,
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=mp-56143-2&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Jan 09, 2009 | Digital Products Hewlett Packard OfficeJet...
No paper in printer
Try using a higher grade/quality of paper. Sounds simple but i experienced the same problem with my HP J6480, and using a better grade of paper cured the problem.
Nov 02, 2008 | Office Equipment & Supplies
HP OfficeJet D135 All-In-One InkJet Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
