Question about KitchenAid Architect ® II KEBS208S Electric Double Oven
I self cleanedthe oven and after I did It does not heat anymore the blower works but the heat does notthe screen is giving me a code of "PF"
  • KitchenAid Master
  • 43,501 Answers
You may have to call the factory for help...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 24, 2010
  • 3,083 Answers
Here is a web blog pertaining to your problem. The first blog describes the PF error coming up, and then turning into another error after they tried some things:
http://forum.doityourself.com/kitchen-laundry-large-electric-appliances/299820-error-code-f2-e1-kitchenaid.html
It could be that you can reseat the connector, or it could be a bad control board, but that would take some testing, to make sure it's not a bad thermostate control, etc.
A lot of people have had problems with Kitchenaid's ovens, and some problems have been settle by Kitchenaid. This site explains problems with the self-cleaning function that many have had:
http://www.ihfex.com/Wall-Ovens/Kitchenaid-Wall-Ovens/
This blog explained how one person had a problem with the self-cleaning function, and Kitchenaid replaced their unit:
http://www.epinions.com/reviews/KitchenAid_DBL_OVEN_T_C_OVER_T_C9
I would contact Kitchenaid, and see if there is a recall or some support they can provide. This is clearly a common problem with these units, and they haven't remedied it, from what I read.
Here is Kitchenaid's support page:
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 23, 2010
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
http://www.appliancepartspros.com/whirlpool-blower-w10176670-ap4369539.html
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 | Ovens
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
Apr 26, 2014 | KitchenAid Ovens
Kenmore Elite c970-418091 wont work after self clean - Code f30
Here is a how it works post I{ wrote a little while back.:The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. With all that said you can try to cycle the controls by turning the breaker of the oven off for a few minutes the n turn it back on. It should then read PF which is normal. Press the cancel button and try it to see if it works. If not then you will need to replace the control board in the upper panel
Apr 26, 2012 | Kenmore Ovens
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
KitchenAid Architect ® II KEBS208S Electric Double Oven Logo
214 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
