Question about Music
My problem is that I have an xr-20 an was wondering what would be the best "bang for my Buck" when it comes to a music program to make the beats transferable to CD at CD quality I'm trying to start slow and don't have alot of money but would love to be able. To listen and share my beats with others thanks in advance.
    President:
  • 1,138 Answers
If you are looking for a straight audio solution Audacity is free and you can do lots with it. I was looking for recording software and got Reaper myself. It is a multitrack audio and midi recording program. It is free to try out and around $70.00 for the licence. One example is if you have a midi to usb adapter you can output midi from your XR-20 through the adapter into your computer into a channel on Reaper, record it as a track and work with it after that. You can edit it as midi or you can also record the audio from the XR-20 onto a track. With VSTi there are free synths on the Internet that you can use as FX for the track and run them using the midi track that you recorded. You can also run sample players that way. Here are some useful links:http://audacity.sourceforge.net/ also http://www.reaper.fm/ In case you don't understand midi or recording here is another link to a site I highly recommend:http://recordingreview.com/ ( It is listed as an attack site but I can vouch for the owner that it is absolutely not.) I downloaded the free Killer Home Recording Setting Up pdf and it is a wealth of free info. This site also has detailed explanations of Midi etc. I am a member of the forum(It is free to join as are the forums at the other sites I recommended). Joining forums is also a great way to meet users of the same gear as you. They are usually quite willing to help you as they have all been using that gear.
Posted on Aug 24, 2010
Sound dies off gradually for a second or two, then comes back. This happens often. Thanks.
It sounds like there is a thermal problem. If you can't make it happen by shaking, or banging on the amp. If it comes and goes with the shaking and banging then there is some loose connection.
If you still have trouble we here at Pro Line Music have a service department and can repair it.
2157368055
May 27, 2011 | Behringer ACX450 Ultracoustic 45 Watt...
When I hit each button, it plays each note twice instead of once. This is without holding down the note repeat button. This same issue happens when I am playing back the beat; each note hits twice instead...
Make sure you are NOT in looping mode. Make sure you do NOT have effects such as reverb inline to the amp and speakers. This will cause an echo of the note.
May 08, 2011 | Akai Xr20 Xr 20 Beat Production...
I use my Peavey XR 8600 with an acoustic duo that I'm in. At my last show, an audience member grabbed and dropped a vocal microphone that sent a sharp sound through the Peavey and shut it down. When I...
Chances are one of the power amps has shorted. Replacing the fuse probably fried additional components. Unless you are electronically adept this is NOT a DIY repair.
Expect that this is going to be an expensive repair as often quite a few transistors and other components fry when one goes in these power amps.
Mar 09, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Akai xr 20 not responding to pc
hello Shan Khy11,
Good day!Try install back the driver components of this Device or update the software,try to see if the conflict is in your OS or on the Hardware.
mastergani
Dec 03, 2010 | Akai Xr20 Xr 20 Beat Production...
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 | Music
Music Logo
116 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
