Question about Homelite Mighty Lite Lawn Trimmer
Feed the string - Homelite Mighty Lite Lawn Trimmer
  • 3 Answers
Both lines run in same direction on spool. Make sure it is not pinched or fed through any of the arms in the spool just coming out one on each side of the hole. Tap bottom on ground while trimmer is running to feed line. Each time you tap it line comes out approx 2 inch at a time Common mistake is when new line is added it gets put on in opposite directions. Both do they same direction-arrows on spool tell the way.
Posted on Aug 25, 2010
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
Homelite string gas trimmer Model ut20811A: 1. Will start with full choke and run with full choke for a while but will not maintain speed when choke is released. 2. String feed will not feed when taped....
If it only runs with choke on, then mixture is too lean or idle set to low.
Adjust mixture initially at 1.5 turns, then move in or out as needed for highest idle when warm.
Make sure no leaks or clogged filter when adjusting.
Hard to say with string feed, but are you sure you are not putting the spool in backwards?
Mar 12, 2011 | Homelite Garden
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
How do you change the string feeder on a ryobi gas
If your machine is a "bump feed" there should be a knob on the bottom of the string feed.....this is a LEFT HAND thread, so turn it clock wise and it should pop free and unscrew....re-string your cartridge and replace it tightening the knob counterclockwise until it stops....that should do it !!!... ;-D
Jul 10, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
String on weed wacker does not automatically advance.
the notice on the trimmer says it has an AFS Automatic Feed Spool, "NO BUMPING REQUIRED". I see that underneath the spool, there's a small plastic centrifugal weightwith a peg on it. . It kinda looks like it might advance the line each time the electric motor starts and stops. If there are loose clippings in there, or if the weight is stuck, it probably would cause the problem.
Apr 21, 2010 | Black & Decker String Trimmer Cordless 12"...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
String will not feed when bumped
I've never had any luck with those stupid bump heads. Every time I would refill them, the string would get caught up. They bind up. I finally replaced the bump head with a string head that you place short pieces of string in. They're not perfect either. You have to pre-cut the string to about 9-12 inches in length, and just replace the piece when it's time.
Jun 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
63 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
