Question about Timex Expedition 40141 Wristwatch
Timex Expedition, beeps very quietly and indiglo doesn't work.
Took my expedtion into Walmart and got the battery replaced cause the indiglo didn't light up. After I got it repaced, the indiglo still doesn't work and it didn't beep at all anymore. Noticed she didn't put the back on the same way it came off so I removed it and put it back on. Now the beep is so quiet i can barely hear it. Is there a contact not being made properly? Or is the watch ruined? Any way to fix the indiglo?
  • 2 more comments
  • Anonymous May 06, 2008
    I aslo changed my battery on May 4th and the alarm beeper does NOT work at all. My Indiglo is OK. Weird.
  • Anonymous Mar 04, 2009
    My beep is so quite I thought the alarm was turned off, but it is on, I can just barely hear it.
  • k8sabins
    k8sabins Apr 09, 2013
    when
  • Anonymous Mar 17, 2014
    button contacts
  • 3 Answers
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
Posted on Aug 18, 2008
  • Andrew Webster Mar 14, 2011
    Make sure the white disc is contacted by the single spring, not the double spring on the opposite side. On my watch this means that the arrow is pointing in the opposite direction, away from the crown button, due "west" on the clock face. I think this is illogical but that's how my indiglo works!
    New Friend:
  • 3 Answers
Make sure you put the sticker back on. I threw mine in the garbage and had to use a tape. Alarm wouldnt go off without the tape.
Posted on Nov 08, 2013
    Sergeant:
  • 302 Answers
You went to WalMart, your first mistake. They know less about your watch than you do. They also use low quality batteries.
Posted on Oct 08, 2012
You placed the cover misaligned, turn to make match the arrow with the crown in the middle.
Posted on Jul 15, 2008
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
I have a ladies timex indiglo watch that I was able to get the back off and replace the battery but now I can NOT get the back on again. It doesnt seem to have any grooves on it. It seems as if it would...
I have an old Timberland Indiglo watch in which I had the same problem. I folded up a paper towel for padding and I used two sets of pliers, one to hold one side of the watch while I used the other set of pliers to snap the back cover closed. It took two seconds to do.
Sep 10, 2010 | Timex 27191 Wristwatch
The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
Jul 07, 2010 | Timex 27191 Wristwatch
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
Indiglo light does not light
Replace the battery for Indiglo function.
Feb 16, 2010 | Timex Expedition 84601 Wristwatch
I have a timex HRM. The indigo light just stopped working. I've had it for 3 weeks. There is a faint light on the edge, but it doesn't illuminate the face. Everything else works normal. Any ideas?
Check out if your watch has second battery for Indiglo function. It is quite common for Timex watches to have two batteries - one for movement and another for Indiglo.
Jan 21, 2010 | Timex 27191 Wristwatch
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex Expedition 40141 Wristwatch Logo
5,094 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
