Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
THERE IS ICE ON BOTTOM SHELF OF FREEZER BOX, WHAT CAN CAUSE THIS
    Problem Solver:
  • 7 Answers
Usually a clogged drain line Also poor door gaskets.
Posted on Aug 23, 2010
Testimonial: "thank you it was the correct solution, the drain line. we were not aware that a cap had to be removed from the line under the unit, been there 7 years"
How to remove bottom shelf to clean inside bottom of freezer?
Good Morning Wayne,
I see that you want to remove the bottom shelf of your Frigidaire freezer, to clean inside the bottom of your appliance. To remove the shelf, you will pull it out and lift it up. If you are having troubles getting the bottom shelf out, I suggest contacting a local authorized technician for further assistance. They will be able to diagnose exactly what is causing the shelf to stay inside your freezer. Hope this is helpful.
-Best Regards-
WP
Apr 28, 2014 | Frigidaire 14 cu. ft. / 396 liter Upright...
Why is there ice build-up on the bottom shelf on an automatic defrost freezer?
It sounds like unit is not properly going into defrost or your evaporator fan motor is starting to go bad
Jan 06, 2011 | Amana 16.7 cu. ft. / 473 liter Upright...
Why is water is gathering and freezing at the front on the bottom shelf of the freezer?
because your drain hole is stopped up clean all of the ice from the area and flush with hot water
Nov 18, 2010 | Woods Upright Freezer V1613RW3
I have Ice on the bottom shelf of the freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | Amana 15.0 cu. ft. / 425 liter Upright...
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Bottom drawer wall is covered s ice/ top shelf not freezing
Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer defrosting
need to defost the whole freezer get the door to close correctly...
May 27, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
205 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
