Question about Cameras
Need a manual for the Canon speedlite 430EX. Can anyone help?
Fujifilm S700 manual
Posted on May 04, 2008
New batteries still no power-up
Check the contact in the batt compartment for obstructions or corrosion etc. No power means broken circuitry - either physical dislodgement of electronic/ electrical parts or damaged electronic components.
Apr 01, 2013 | Canon Speedlite 430EX TTL Flash
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
No wireless on my 430ex flash
This Canon flash gun does not have a true wireless (radio) trigger. It uses optical light pulse.
A user manual can be downloaded from this WEB site.
http://support-au.canon.com.au/contents/AU/EN/0300411601.html
Dec 26, 2011 | Canon Speedlite 430EX TTL Flash
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Can't find the serial number on my 430EX speedlite. where is it located?
This is where I found mine:
It's a 6 digit number located on the top half of the flash (the bit that tilts backwards and forwards). On one side it says Speedlite 430EX II, on the other side there are a few symbols and underneath is the serial number engraved on the plastic.
I also found it printed on the warranty card that came inside the box.
Mar 22, 2009 | Canon Speedlite 430EX TTL Flash
Make sure it is not set to manual 'M' on the display. To get it to shoot in ETTL (Through the lens) press the mode button and it should read ETTL in the top left corner. This then means that the light is metered thorugh the lens and you are not relying on the manual settings.
Hope that helps. I had the same problem when i first got my.
By the way a brilliant all round bit of kit. I have traveled the world to some fairly extreme temps and got it wet (Rain, humidity, sea spray to deserts and serious dust) All good.
Good luck
Apr 14, 2008 | Canon Speedlite 430EX TTL Flash
Canon Speedlite 580EX
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
