I have an admiral desighner series washer model #LNC6742A80.My washer will fill up with water but wont agitate or spin.It does make a noise while its supposed to be washing but it wont agitate.After the washing cycle is over the water does drain out but still does not spin.Where do I begin?I want to repair it myself but I dont know where to start.I hope you can help
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Posted on Nov 24, 2007
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series won't spin
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
  • 221 Answers
SOURCE: Admiral washer won't agitate,drain, or spins
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Posted on Jan 08, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Jan 06, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
