Question about Dryers
I have a kenmore dryer, model 41781142000. The timer will not turn off. It just keeps going. The dryer only turns on about every 10 minute for about 2 seconds and stops. When the timer gets to the off area it just keeps buzzing until I turn it. Even when I turn it to off the timer just keeps going. The separent on switch doesn't do anything. (maybe because the timer says its already on?). What could be the problem? Please help. I had to unplug it from the wall to stop the timer.
  • Dryers Master
  • 43,501 Answers
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore Elite Dryer 63942 Push on button, turn the timer to 30 minutes.Within 10 minutes the dryer shuts off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2010 | Kenmore 63942 Dryer
I have an older model...........maybe 8-10 yrs and i turned it on lastnight and this morning it was still running. the knob that is like the timer didnt even move???? i opened it up and the clothes were...
The gas turned off when the temperature is detectd by a thermal sensor. The timer is not working therefore the motor keeps running until you turned it off. The timer need to be replaced.
Apr 27, 2010 | Kenmore 72602 Gas Dryer
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
KENMORE 41781142000 DRYER NO HEAT BUT RUNS...
temperature selecctor switch or timer is bad
Nov 25, 2008 | Kenmore 63942 Dryer
Kenmore elite model 110639101
check for blocked vent tube.You should have a very strong flow coming out.If it is weak it will run badly.It is a common call.If its not weak air flow than run the dryer for at least 20 minutes.Open the door and if has no heat inside .......change the split coils. Please Rate This !!!
Sep 15, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer
yes it does sound like the timer itself. sometimes if the timer has a bad contact then the timer will loose power as it goes around. by turning the timer around 1 time it resets the contact and it starts up again.
Jun 28, 2008 | Dryers
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Kenmore 90 Plus Series Model: 68942890
bald one, more than likley your even heat board has failed. I've seen this a lot on this model. It's located under the consol right next to the timer. Easy fix. part number 3402605. Catriver
Jul 14, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
