Question about Microwave Ovens
Jenn-Air Electric Range S166 Service Manual - Microwave Ovens
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: I have a Jenn-Air Gas-Electric
Hi
Thanks for using FixYa. Error F2 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 22, 2010
  • 5474 Answers
SOURCE: I purchased a house w/
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
Posted on May 08, 2011
GodBlessU
  • 3513 Answers
SOURCE: Hi, my Jenn Air slide
Hi
Since the part is no longer available,it is suggested that you contact Jennair dealer or customer support to get assistance.They only can give you the proper suggestion or right details for replacing the relay board with the changed part number.
Thanks for contacting fixya.com
Posted on Jul 26, 2011
Manual for jenn air microwave jmc8130dds
Like most manufacturers these days, Jenn-Air offers manuals online. I did not see specific instructions for removing the panel, but here is a link to the parts diagram which may offer some hints. You can also call or chat online with Jenn-Air Customer Care.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JMC8130DDS.pdf
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
Jenn air microwave model jmv820aas shut down completely, what do i do?
I'm guessing you might mean JMV8208AAS?
If so, then the service manual is at our site here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Jenn Air parts here.
Your problem will be either the line fuse, or one of the thermal cutouts / TCOs in the unit.
In case it needs circuit board repair, see this link.
Nov 27, 2012 | Jenn-Air JMV8208AAS Microwave Oven
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
May 08, 2011 | Jenn-Air Microwave Ovens
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
I have a Jenn Air JMV8209AS and I want to change the interior light but I can t locate it. Am I missing something here obvious here?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 12, 2009 | Jenn-Air JMV8208A Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
My jenn-air microwave makes a LOUD humming noise
More than likely the power inverter board has been damaged and it would be best to stop using it immediately.
Jenn-air products are very good quality and quite expensive to replace. I would contact Jenn-air service and have a service tech dispatched to determine the exact problem and the cost to repair it. Jenn-air stands behind their product 100% and should be able to repair the unit for you.
http://www.jennair.com/content.jsp?name=local_service_repair
Follow this link to Jenn-air service and repair.
Cheers,
Keith
Jan 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Microwave Ovens Logo
207 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
