Question about Mountain Buggy Urban Elite Double Stroller
My front wheel piece came off how do i get a new black piece and the special nut to keep the wheel on
I called them and they told me the nut you can get at any hardware store. I tried. It's not easy. If you find one please let me know. The plastic cap. You can buy that from mountain buggy for $0.99.
Posted on Sep 30, 2010
HOW DOES ONE REMOVE THE STEERING WHEEL!
Hi Stephen, Keep in the fore front of your mind that the steering wheel is fitted with an explosive air bag. The center piece of the steering wheel is removed by removing the fixing screws rom behind the steering wheel. Once those have been removed, disconnect the electrical connections by unplugging and place the unit aside. Behind that is the fixing nut holding the steering wheel. Loosen it and then using a puller remove the steering wheel. Behind the steering wheel is a special cassette which contains a special wiring loom which must be realigned correctly if removed or if a new unit is fitted. Failure to align it will result in it being broken or damaged. Reassembly is opposite. Regards John
May 23, 2014 | 2006 Volkswagen Caddy 1.6
How to remove gokart golf trolley front wheel
Paul, your solution does not apply to the GoKart electric golf trolley. Please use the following procedure to replace the bearings in the GoKart front wheel;1. Unscrew one of the round black plastic nuts on the end of the front wheels spindle.2. Hold the remaining nut, and by twisting and pulling on it, the front wheel spindle can be pulled out.3. You can then remove the front wheel.4. Remove the old bearings and fit the new ones. They just push into the front wheel.5. Clean and grease the spindle before re-assemby.
Jan 06, 2013 | Cars & Trucks
How can I fix cross threaded wheel screws?
Go to the auto parts store and borrow a nutcracker. Attach the nutcracker to the stuck nut. Tighten the nutcracker with a rachet wrench until the cracks completely in half. Now you can remove the wheel. Buy a new wheel stud and lug nut. Your lug nut will be pressed into a metal piece. Remove this piece and either 1) support the metal piece, put a good amount of penetrating oil on both sides of the bad lug nut and tap firmly with a large hammer. Let this sit for 5-10 minutes so that the oil can penetrate the stud. Now pound out the old lug nut with a large hammer. If it will not budge, then you can try heating the stud with a torch until it is quite hot and then hit the stud progressivly harder until it comes out. Now insert the new stud and pound it in until it stops moving. Last, before you reassemble, put the lug not on the new stud and tighten it real good to make sure that the stud is comletely seated. 2) the other option is to take the metal piece to the parts store and let them remove the stud and press a new stud for you.
Jun 24, 2012 | 2003 Honda Accord
Need to replace 2003 corola front wheel bearings. need step by step instruction please
Removal & Installation To Remove:
  1. Remove the front wheel.
  2. Remove the front axle hub nut.
  3. Disconnect the front stabilizer link from the strut.
  4. Disconnect the speed sensor (with ABS).
  5. Remove the front brake caliper and rotor.
  6. Disconnect the tie rod end.
  7. Remove mounting bolts and nut and separate the lower control arm from the ball joint.
  8. Using a plastic hammer separate the front axle shaft from the hub.
  9. Remove the 2 mounting bolts from the strut. Remove the knuckle and hub assembly.
  10. Remove the lower ball joint from the knuckle.
  11. Remove the axle hub snap ring from the knuckle. toy_car_cor-02-04wheelhub2.gif
  12. Remove the axle hub from the hub bearing using special tool 09520-00031 or equivalent hub puller.
  13. Remove the inner race from the axle hub using special tool 09950-40011 or equivalent puller.
  14. Remove the dust shield from the knuckle.
  15. Remove the axle hub bearing from the knuckle using special tool 09520-00031 or equivalent and a press.
To Install:
  1. Install the axle hub bearing on the knuckle using special tool 09950-600020 or equivalent and a press.
  2. Install the dust shield on the knuckle with 3 mounting bolts.
    • Tighten 73 in-lb (90 Nm).
  3. Install the axle hub on the knuckle using special tool 09950-600010 or equivalent and a press.
  4. Install the axle hub snap ring.
  5. Install the lower ball joint on the knuckle.
    • Tighten the ball stud castle nut 76 ft-lb (103 Nm).
  6. Install a new cotter pin.
  7. Install the knuckle on the strut with the 2 nuts and bolts.
    • Tighten 162 ft-lb (220 Nm) (except '03-'04) 113 ft-lb (153 Nm) ('03-'04).
  8. Lift the knuckle and hub assembly over the axle shaft and into the hub splines.
  9. Install the lower control arm on the lower ball joint.
  10. Connect the tie rod end to the knuckle.
  11. Connect the stabilizer link to the strut.
  12. Install the front rotor and brake caliper to the knuckle.
    • Tighten the 2 caliper bolts 79 ft-lb (107 Nm).
  13. Install the ABS sensor if equipped.
  14. Install the front axle hub lock nut.
    • Tighten 159 ft-lb (216 Nm) and stake the lock nut.
  15. Check the axle hub backlash and run-out.
  16. Install the front wheel.
  17. Check the front wheel alignment and adjust if necessary.
Feb 17, 2011 | Toyota Corolla Cars & Trucks
We keep breaking off the front wheel bolts each time we try to take a wheel off. Very difficult to find here in Canada. Special shipments from Montreal. Is there a better way? Would changing to a...
We are talking about lug nuts here correct and the studs are snaping off You can try getting cap nuts the stud dosn;t stick out the end and what i do is when i take the wheels off i always spray a little wd -40 in the nut then torque 85 lbs this should solve your problem
Nov 17, 2010 | 2004 Dodge Sprinter
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Aug 15, 2017 | Little Tikes Cozy Coupe 30th Anniversary...
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
The front wheel assembly is wobbly. Cant seem to find a new wheel anywhere. Thought that fixing it would be cheaper than getting a new trike but maybe not?? Thanks Jodie
you'll want to start by taking the front wheel off of the bike. there are two nuts on the axle on each side of the hub. (besides the ones you loosened to remove the wheel) the two inside nuts keep the bearings tightly in position inside the hub, and the two outer nuts are jamnuts that are tightened to the two inside nuts to keep them from turning once you've got the tension set. so loosen the jamnuts from the tension nuts, set the tension tight to where the wheel doesnt wobble but not so tight that the wheel doesnt spin freely. then tighten the jam nuts while holding the tension nuts in place with a wrench so that the tension nuts dont move when you're tightening the jam nuts. take your time and you'll be fine. I hope this helps and Good luck!
Feb 18, 2010 | Cycling
Replacing the right wheel bearing how do u remove that hub do u need a special tool for it
is it a 4x4? the wheel bearing comes with a new hub assembley . Just find out what size the front half shaft nut/ lock nut/axle nut- is. its probably a 33mm thats the only special tool you will need. Unscrew it, take your outer tie rod off the spindle/steering knuckle, theres 3 bolts behind it, take them off then disconect the abs harness and pry out the old hub assembley use a rubber hammer (dead blow hammer) to tap the half shaft out if seized. when installing the new wheel bearing see your manufacturer specs. for torquing the axle nut back on.
Feb 16, 2010 | 2001 GMC Jimmy
2005 elantra need answer on removing rotors
REMOVAL:
Loosen the wheel nuts slightly. Raise the front of the vehicle, and make sure it is securely supported.
Remove the front wheel and tire from front hub.
Remove the split pin, then remove castle nut and washer from the front hub while applying the brake.
Remove the caliper mounting bolts, and hang the caliper assembly to one side. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper from the undercarriage.
Remove the wheel speed sensor from the knuckle.
Disconnect the tie rod end ball joint from the knuckle using the special tool (09568-34000).
Remove the split pin.
Remove the castle nut.
Disconnect the ball joint from knuckle using the special tool (09568-34000).
Remove the lower arm ball joint mounting bolts
Remove the strut lower arm mounting bolts
Remove the hub and the knuckle assembly
INSTALLATION:
Reverse the order of the removal procedure.
May 23, 2009 | 2005 Hyundai Elantra
Mountain Buggy Urban Elite Double Stroller Logo
209 people viewed this question
Top Mountain Buggy Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Are you a Mountain Buggy Baby Gear Expert? Answer questions, earn points and help others
