Kenmore 80 series wont agitate. - Washing Machines
  • lap1 Jun 04, 2008
    I put wet towels from wiping up a lot of water in the washer - it filled up with water, but just stops. It will not aggitate or drain.
  • Anonymous Nov 06, 2008
    The water won't drain.
I am told that the belt need adjusting, tightening. How is this done? John
Posted on Oct 22, 2008
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
