Question about Carrier 38CKC042 Air Conditioner
My air conditioner is blowing hot air instead of cool air.. what is wrong with it? I have a Freyven mini split and the compressor turns on and off in a matter of seconds. It doesn't cool the room at all. It has The R-22 at the correct specifications but I just can't seem to figure it out. I have had several so-called technicians come and check it but it is still the same. What is the problem.
  • guero1 May 25, 2008
    My air conditioner is blowing hot air and not cooling the house. I checked the wiring outside and everything appears fine. Any quick fix solutions?
    Scholar:
  • 149 Answers
First if it turns on and off does this trip the breakers?? I'd recommend you to change the combination capacitor and check against wiring diagrams probably a misplaced wire that can do what your describing. check that you have your remote set on cooling to 21c or 72 f if you need any other help e-mail me at hvac.tech7872pr@gmail.com
Posted on May 05, 2008
Not blowing cold air tough there is an airflow, how can I repair it?
if no air come from indoor unit then indoor fan motor problem and if air come but not cool then check it gas from out door unit if gas present then change its compressor capacitor it will be ok
Jul 25, 2012 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
My AC is blowing hot instead of cold air, what can i do
Compressor not getting power. Or not functioning. Take assistance from the service provider. you have to check all the relays and commands which may be difficult!
May 26, 2010 | Continental Electric CE-AC7581 Ductless...
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Carrier 38CKC042 Air Conditioner Logo
211 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
