Question about GE GFSS6KKYSS (259 cu ft) Bottom Freezer Commercial French Door Refrigerator
DOES NOT MAKE CRUSED ICE OR CUBES ONLY CHUNKS
I have the same problem. Did you get an answer?
Posted on Aug 23, 2010
Ice maker makes large chunks of ice about half and other half of ice is normal ice cubes
check you Ice maker is it level...if level I would check the water level you may be getting to much water in to it...
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
It keeps crushing ice even though I have followed all directions for cubes
THe crusher is stuck. With small chunks of ice. Remove it dump all Ice and allow to thaw or rinse with water, dry and reinstall. Shut the Ice Make head off (lift the wire bail) so ice will not drop in the floor of the freezer. turn back on when all is back together.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
In side by side whirlpool refrigerator freezer ice cubes stick
if they are hollow and stuck together then u are not getting enough water..check the supply.
Jun 09, 2009 | Refrigerators
I have a Frigidaire refrigerator Model FRS6L9EFSS0
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or crushed ice , or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Jan 13, 2008 | Frigidaire FRS-26DR7D Side by Side...
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
GE GFSS6KKYSS (259 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
