Question about Sennheiser HDR 120 Consumer Headphones
Sennheiser H120 earphones (wireless) No sound from right earpiece - left is fine?
3 Suggested Answers
  • 7 Answers
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Posted on Apr 02, 2009
  • 31 Answers
SOURCE: Sennheiser HD201 headphones. Left hand cable
there will be 2 wires in different colors inside the cable,
these wires are enamel coated and sennheiser has best quality coating over the wires, so soldering this could be a bit messy - this is the procedure to do so
first take out these wire leads out for about a centimeter from both the ends, try to loosen the leads and yo will find small clustered strands of fiber wound between the leads try to remove those fibers (only the visible ones) completely from both the ends of the exposed leads.
take a blade and try to wipe out the enamel coatings from the wires (make sure that the 2 leads does not touch each other after removing the enamel) now connect (solder) both the ends of the wire with their respective leads (eg. red with red or green with green as applicable) now you should be good to go
Please understand this is a delicate job and require atmost attention use cello tapes wherever applicable and tie knots at correct places to avoid further damages
Posted on Jan 30, 2011
How do I get the tv sound on after plugging speakers into audio on my TV?
That's what's 'sposed to happen. You get TV sound OR sound through headphones - not both
Nov 28, 2015 | Sennheiser Rs 180 Digital Wireless...
Why have I lost volume in one ear
there will be some loose connection in wire...or else u may have dropped down the earphone....maximum it will be wiring problem....
Aug 20, 2014 | Sennheiser Genuine Cx270 Cx 270 In Ear...
Louder in one ear than the other
There is a possibility that your earphones need cleaning. Take off the tips and gently brush the metallic mesh with some cloth. Then dip each earpiece into drop of alcohol (you need to dip mesh only, not the whole earpiece). Then wipe it clean with cotton bud or something similar. Next, dip your earpieces the same way into drop of hydrogen peroxide and leave them there for few minutes. After that, wipe them again.
I used this method on my ie8 and it really helped.
Feb 21, 2012 | Sennheiser IE8 Headphones
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
I have had a pair of sennheiser earphones for years but recently they have started to loose certain sound pitches e.g. vocals and some times the base goes a bit muffled. this only happens when the...
It's likely the groud connection in the cable is broken. Possibly at the plug, it would mean no centre focus and no bass as the headphones get only out of phase sounds. I'm guessing you've tried them in another device - a faulty sockey would do the same.
Dec 25, 2017 | Sennheiser CX 300 Consumer Headphones
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
Sennheiser mm200 totally dead
Well I have had the same problem as well, twice really. The first one got replaced by Sennheiser, very good service. Unfortunately about a year later the same problem, I am waiting now what they will do with this. I really like the little earphones but I need them to work. Untill now I have had great service which of course comes with the quality of the name.
Sep 21, 2009 | Sennheiser MM200 Premium Bluetooth Stereo...
Earpiece problem
pl shake the earphone which is not hearing well
Jun 10, 2008 | Sony Ericsson Walkman® W880i Cellular...
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Feb 24, 2008 | Apple iPod nano
Sennheiser HDR 120 Consumer Headphones Logo
143 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
