Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No picture but I have sound
My tv making a poping sound when you turn the t.v. off. Then one day there was a loud pop. Now I have sound but no picture.
  • 137 Answers
Dificult to say there can be a lot of stuff that could go wrong. Sory you must take it for repair at your nearest tech.
Posted on Jun 29, 2008
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Picture but no sound
the loud pop was a capacitor or a resistor popping, it will need replacing.
Jun 19, 2017 | Vizio JV50P 50 in. Plasma TV
Vizio model vx322 hdtv10a is losing sound and makes a loud humming noise and a poping sound every few minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | Televison & Video
Loud poping and cracking sound
sounds like the high voltage problem from high voltage socket, check with an expert tech.
May 05, 2009 | Akai PT4298HD Rear Projection Television
Loud poping noise
It sounds like the popping noise you heard was a capacitor blowing its top somewhere in the tv. Sorry I cannot be more specific but if you manage to find out where this cap has gone also check any resistors near it as they can be also damaged. If you cant do this call out a competant technician. Good luck.
Jul 28, 2008 | Samsung HC-P4752W 47" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
No picture
sounds like high voltage arcing,/flyback,focus block,h.v. anode lead etc.
Sep 07, 2007 | Toshiba 55H70 55" Rear Projection...
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
