Question about Kenmore Dryers
Kenmore gas dryer model number 111.76712693 no heat coil wont light up do you think its the igniter sabrefan29@yahoo.com
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Kenmore 70 series model #97573200/stock # 75732. It's a gas dryer with an electric igniter. The problem is, dryer runs but there is no heat. I'm thinking there's a problem with the igniter? ...
if the ignitor is lighting up, the problem is going to be in the coils that are attached to the gas valve itself, heres what they look like http://www.applianceaid.com/images/2coilsgenaralgas.JPG
Jul 04, 2011 | Kenmore Dryers
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Initial heat cycle will ignite gas burner but will not re-ignite to maintain heat.
MAKE SURE YOU HAVE GOOD VENTILATION TO OUTSIDE. CHECK THE COILS IN THE GAS VALVES. CHECK CONTINUITY ON BOTH COILS. SHOULD READ 1.3 - 1.9 OHMS. ON THE COIL WITH THREE TERMINAL, MEASURE BETWEEN MIDDLE TERMINAL AND OUTSIDE TERMINALS
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Dryers
My kenmore model 70 wont heat. I replaced the coils, and gas sensor. the unit has been thoroughly cleaned. the igniter is heating up, the gas will light, then goes out a few seconds later. the unit is a...
Hi, Make sure the 4" vent is clean al the way outside. Make sure the vent hood in the wall is open. It sounds like the heat is short cycling do to poor air flow.
If the vent does not appear to be an issue, Watch the ignition while running and see if the ignitor glows later in the cycle and shuts down before the flame ignites. If this happens, you will need to change the coils on top of the gas valve. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 27, 2009 | Kenmore 63942 Dryer
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
