Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool ultimate care 2 can i turn the buzzer off or down
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 360 Answers
SOURCE: I need to find out how old is my Whirlpool Washer Ultimate Care 2
The copyright on the owners manual is 2003.
Here is a -->link<-- to download the manual if you would like.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 10, 2009
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: replace a lid switch on a whirlpool ultimate care
Lid switch replacement video and service manual
Posted on May 02, 2011
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Timer turning, draining properly, but agitator not turning... Any suggestions? whirlpool gold ultimate care 2 agitator
    The direct drive coupling between the motor and transmission is broken and must be replaced.
    This video shows how.
    Jul 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    Ultimate Care 2 Washer, Bottom half of agitator not turning
    The problem is simple and inexpensive to fix. The agitator dogs are worn and need to be replaced. The following link explains:
    http://www.fixya.com/support/r823955-replacing_agitator_dogs
    Read through the instructions and let me know if you have any questions. Use the part number provided for ordering any replacement parts. I hope this helps you.
    Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    clarkco
    Feb 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool washer has begun to make a loud buzzing sound when the
    This machine has an end-of-cycle buzzer built in. It may be that it just started working.
    Dec 31, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool ultimate care 2 washer wont spin
    Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
    Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Thin Twin
    Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
    Mar 16, 2008 | Washing Machines
    Buzz when changing cycles
    there isnt, or at least shouldn't be a buzzer to let you know its changing cycles, only end of cycle. if its buzzing betwwen cylces theres problem a woudl assume eith timer( if theres a selector forit try turning of end of signal chime any way
    Feb 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    116 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
