Problem associated to the booting sequence, the 'my computer window ' is divided into four fragmentations .at the floppy and dvd. thedvd is not highlighted therefore imposible to access thecd player
    Master:
  • 515 Answers
You mean the CDROM or DVDROM is not selectable as a booting option in the BIOS, right? There must be something wrong with the device, the driver or your BIOS. Is your hard disk still bootable? If so, you can boot in hard disk and see whether the DVD-ROM is still there and check the device manager of your Control Panel to see if any errors about it. If it is not working there, you can check whether all the cable connections are connected well and the jumper settings are fine. There could only be one master device on a single ribbon of the IDE interface. So if you have a hard disk and your DVD-ROM connected to the same ribbon and the jumper settings of both are set to master, you will need to adjust one of those settings to slave or cable selection. Then you can use the AutoDetect feature of your BIOS to detect the CD-ROM if available. If those are not working, you can uninstall and reinstall the driver of your DVD-ROM if available when you boot in hard disk and open device manager for hardware change scan or directly right click on the CD-ROM icon in device manager and select update driver then select the right driver downloaded from the manufacturer's web site. You can also plug that DVD-ROM to another computer and see whether it is working there to detect mechanic issues of it. If everything is working on the other computer about this DVD-ROM and it is not working on yours, you can also try to flash your BIOS and/or replace the ribbon and see if it works before you replace your motherboard.
Posted on Aug 23, 2010
Dell computer, did acronis recovery and it backfired on me
Is your boot sequence such that the CD drive is polled first? Do you have a CD or DVD drive? Turn off the computer and turn it on again; press F2 at the first screen (happens fast) and on the BOOT tab, insure that CD drive (not floppy) is first in the boot sequence.
Mar 01, 2013 | Computers & Internet
Reboot with cd
Hi Friends
If you want to Boot your computer from CD or DVD in this case you have to set the "Boot Sequence" from BIOS. Follow then mention below instruction and try.
  1. Restart you Computer and press the "Del" key from when computer is boot.
  2. Your will see one Blue Screen with lots of option.
  3. Select the "Boot configuration" and select "Sequence"
  4. There you will see some option like "First Boot :- HDD, Second Boot:-CD-Rom, Third Boot :- Floppy Drive. ect.
  5. So what you should do you just select the "First boot :CD-Rom"
  6. For move the option you see the down help windows and configure the boot sequence .
Thanks to Visit Fixya...
Sep 07, 2012 | Lenovo 3000 Y410 Laptop
I have a hp pavilion dv4 1225dx screen is black number and cap lock keep flashing wat should i do
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer.Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file - keep reading at http://support.microsoft.com/kb/314503
Apr 30, 2012 | HP Computers & Internet
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
Sep 19, 2010 | Computers & Internet
My computer says invalid boot diskette_A. AND IT WILL NOT LOAD WINDOWS XP. Then sometimes it loads perfectly. What makes this happen?
make sure there is no disk in floppy drive or any cd -dvd in rom dive if it is there just remove it and in bios set up a booting sequence first drive with hdd.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 02, 2010 | Computers & Internet
I con not setup win xp on the hard without floppy disk
Start your computer. Enter BIOS SETUP. Select "Boot Order". Configure to make the CD/DVD the *FIRST* boot-device. Put the Windows CD/DVD into the drive. Save/Exit from BIOS SETUP. Your computer will restart, and will "boot" from the Windows disk in CD/DVD drive.
Jun 08, 2009 | ASUS P4S800D-X Motherboard
Whenever i shutdown my computer and restart it again only a black screen with mouse pointer appears in the welcome screen and then only if i change the first boot-in device to CD Rom i am able to log in,...
Hello my name is Tim Ehrhart and I believe If this pc has a floppy drive (3.5 mm) and it is first on the boot sequence then it sounds like it is a bad floppy drive and needs either removed or replaced, try setting the dvd drive to be first in the boot sequence and save it so it is always first. also try testing your floppy drive. hope this helps you out
Mar 13, 2009 | Mercury P4VM800M7 Motherboard
Boot problem - Win98SE
change the boot sequence in bios set up ...
keep in this order
first boot device as floppy
2.hard disk
3.cdrom
then save it and then have a check it should work ..
you have not mention hard disk here so i think the hard disk is not detected there may be some loose contact inside and it is not connected properly so it is not able to verify DMI pool ...
if so connect the hard disk properly then then have a check it will surely work..........
Feb 23, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
David Payne
David Payne
