Question about Alpine CDA-9827 CD Player
My alpine CDA-9827 is currently not turning on. We took of the face plate and it was unused for a couple months and now that I put it back in, it wont turn on. No lighting up, no sound, no nothing. I live in Arizona so could it be that the heat did something to the wiring? I also cant seem to get the deck to pull out of the car so I can look at the wiring. It is in there tight. Is there some sort of release button to get it out?
  • Alpine Master
  • 17,129 Answers
There is a lock whicch has to be removed by inserting the KEY that comes with the set . However if you do not have this with you , you might have to use thin flat blade of about 10 cms width to push into the sides after removing the front panel.
Before the set is removed check for the fuse on the fuse panel , If fuse is Ok then the set has to be removed.
Once the set is removed then the positive from the switch and the main continuous positive must tbe present on the line. if not trace and correct.
However if the power is fine then you have to clean the front panel and also the connections on the base panel. Fix the front panel. If the set does not power then you will need to open set and check on the mother board for failure of the regulator, the micro controller, check power to these sections.
Posted on Aug 23, 2010
Is the CDA-9827 capable of playing songs from an mp3 player (does it have an input option)?
The Alpine CDA-9827 only has an input connector for an external CD Changer.
You could get an FM Transmitter for your MP3 Player, and play your MP3 Player using your FM Radio in your Stereo.
Here is an excellent MP3 Player FM Transmitter:
http://astore.amazon.com/tps03-20/detail/B000E43GOO
Here is a copy of your Owners Manual.
Jul 24, 2010 | Alpine CDA-9827 CD Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
I have a Alpine CDA 7875 face plate, want to know
hey do you still need a deck? or would you be willing to sell me the face plate? let me know...
Sep 28, 2009 | Alpine Car Audio & Video
Alpine CDA 9827 using aux mode with ipod shuffle via rca inputs
Unfortunately, the rca outputs are to control an amplifier or crossover. They do make an ipod adapter for that radio, which allows you to control the ipod through the radio. Best Buy or any Alpine dealer should carry something for around $25.
Jul 05, 2009 | Alpine CDA-9827 CD Player
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Alpine CDA-9830 doesnt want to work
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
Feb 07, 2009 | Alpine CDA-9830 CD Player
Alpine CDA-9827 distoration
do you have an amplifier in the car also? if you do then there is probably a problem with the install. also could be a bad ground.
Aug 16, 2008 | Alpine CDA-9827 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine CDA-9827 CD Player Logo
93 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
