Question about Craftsman 16" Variable Speed Scroll Saw
My Craftsman 16" variable speed scroll saw worked fine the last time I used it. I tried to use it yesterday and now suddenly it seems to have the bottom arm of the saw working in opposition to the upper arm, thus causing the blade to bend and then snap back. The only thing I did was to attempt to loosen the adjustment on the knob on the back of the saw. Any ideas what I need to check? Thanks
    Problem Solver:
Try retightening the tension knob...not sure exactly hows its hooked on,but sounds like you may have backed it out too far.If simply turning the knob to tighten does'nt work,try either pulling up on knob a little while trying to tighten..or opposite-push down on it while trying to tighten...the idea with both is to get the threads on the tightening knob to catch the nut inside...my guess is it came off.
Posted on Dec 27, 2010
I have a 923611 direct drive scroll saw. Where can I get a yellow switch key?
Try this link. The part has been substituted.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113235501/0247/0744440?blt=05
p.p1 {margin: 0.0px 0.0px 10.0px 0.0px; font: 12.0px Verdana; color: #333233; background-color: #fdfcb7}
Manufacturer authorized substitution: 22256 may differ in appearance, but is a functional equivalent to prior parts including 9-22256.
Jan 14, 2011 | Craftsman 16" Variable Speed Scroll Saw
How can I get an owners manual for a Craftsman 16"
I have one. E-mail guy1der@msn.com and I will copy and send one, no charge.
Nov 30, 2010 | Craftsman 16" Variable Speed Scroll Saw
My 16" craftsman scroll saw has a rubber tube that
The tube can be replaced with the plastic tubing used for aquarium air pumps that you can find in most pet stores. Unfortunately you have to disassemble the scroll saw arm to replace it. Remove the 6 screws at the back of the arm assembly, then the 4 bolts that hold the arm to the base. This will allow you to split the arm and you will find a plastic bellows that the hose connects to.
Nov 13, 2010 | Craftsman 16" Variable Speed Scroll Saw
After turning on the saw, it will run about 10 seconds and then will trip the breaker. This happens every time .. the motor is not overheated. The saw had been working fine but this just started recently....
Is there a breaker on the saw, or do you mean the breaker in the electrical panel? Maybe you can borrow a clamp-on current meter to investigate. You might have a bad breaker. I would suspect an intermittent short, but it wouldn't be so consistent.
Mar 20, 2010 | Craftsman 16" Variable Speed Scroll Saw
Saw blade broke. motor won't run after changing blade. reset wasn't tripped. lite still works so its not in the power cord.help! this is a craftsman 16 in. variable speed scroll saw not used very much....
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Jul 17, 2009 | Craftsman 16" Variable Speed Scroll Saw
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Changing control switch
Sorry, but that is not going to work ,that motor is not compatible with that type switch. you would need a variable speed motor.Newer models have many more improvements, you should try one of them,much smoother cut. Good luck and please don't forget to rate this answer.Thanks.
Mar 29, 2009 | Saws
Craftsman 16" Variable Speed Scroll Saw Logo
282 people viewed this question
Top Craftsman Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
