Machine overflowed floded entire laundry room and around 24 houers after I was able to drain it (with spin only) but the machine wont start now
  • 240 Answers
Need more info
Posted on May 04, 2008
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washing machine keeps getting water in it after the cycle is over. This morning I came in and my empty washer was filled with water and had overflowed onto the floor. Help! There are also times when...
mine also remains wet and soggy, even after the spin cycle. However, I have not, as of yet, (and hopefully won't) begin having overflow problems.
Mine is jumping around the laundry room - as though in an unbalanced cycle. We discovered that one of the "feet" that the washer stands on needs to be adjusted, upward or down, so that the washer stands balanced and evenly. The "foot" does not make contact, and when we turn it to change its height, it just goes in circles without changing height.
Mar 09, 2010 | Whirlpool Washing Machines
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer wont agitate or spin
If this machine is a drum type and NOT A TOP LOADER (There was no mention of the model) then the overload has possibly caused the drive belt to either break or jump off the drum pulley.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
If the belt has slipped off or has broken, it can be replaced by fitting the (new) belt around the motor drive pulley (small end) and refitting around the drum pulley, you can do this by feeding the belt around the drum pulley, by holding the belt in place and feeding onto the pulley (IT IS EASY TO GET YOUR FINGERS NIPPED BETWEEN THE BELT AND LARGE DRUM PULLEY WHEN ATTEMPTING TO FIT BELTS BACK - SO BE VERY CAREFUL)
Best of Luck!!
Jul 04, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not spin
that wont cause it not to spin but it just jerks the tub around a bit stronger.you most likely have a bad clutch.you can take front panel off and see if your clutch is grabbing when you put it in spin.it is under the motor.
Mar 12, 2009 | GE WBSR3140DW Top Load Washer
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
