Question about Zanussi 21 in. DCE5655 Free-standing Dishwasher
The spray arm is very loose and catches the bottom of the basket stopping the spray arm from turning. can you please advise.
We have a kenmore elite 66516593200 that has been leaving grid in some galsses and cup. Any ideas why or how to fix this?
the grit is from the detergent , maybe your using too much for your cycle , ck your owners book for proper amount , in older diswashers the spray arms stop moving and jam up this does same thing and dishes arnt being cleaned , i use the masking tape test , place one piece of tape to end point of basket and stickit dont wrap it to wire basket (bottom) , close up door and run on wash for 15-30 seconds if tapes are not loose then arms arnt moving and need attention or replacemnt
Feb 20, 2015 | Kenmore Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
Hi there, I have an ESL424 Electrolux dishwasher and I'm having some problems with it not washing dishes properly. Is there any common reason for this? The problem seems to be more apparent in the top...
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Jun 25, 2011 | Electrolux 18 in. ESL424 Built-in...
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I have a built in Electrolux ESL624 in the house I've just moved in to. I have noticed that items placed on the top shelf like glasses and cups are not always cleaning properly. Black deposits are being...
Check the spray arms are not clogged as well as the top one take off the bottom one clear a hole underneath the arm. make sure the arms can turn freely. dishwasher fresheners hanging on the basket can stop the arm turning. clean the filter in the bottom. Is the machine heating it should be hot at the prog end.
Aug 04, 2010 | Electrolux 23 in. ESL624 Built-in...
I have a bosch dishwasher silence , when it finishs wash i open the door and find the tablet falling on the bottom or hanging on the container of the tablet part, which did not use at all..please advise,...
Check top basket is straight and moves back fully, remove top spray arm and check holes are not blocked. The water pressure from the top arm is deminished if they are blocked and once the dispenser door opens it is the top spray arm water that propels the tab into the tank. Also, check that when your tallest item is in the bottom basket it does not obstruct the rotation of the top one.
Hope this helps to give you a starting point to remedy fault.
Jul 22, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Seal round door leaks
If the water is noticed at the bottom of door it is probably the seal at the bottom (very unusual for the tank seal to leak, however it is just pushed in, so you could take it completely off, give it a clean up and put it back in) or one of the spray arms is restricted and instead of rotating the water is spraying continually at the corner of the door. Check all hole in the spray arms are clear and if you have a dishwasher freshener make sure it is not stopping the top spray arms rotation field. You could also check that the top arm is clear to move when your dinner plates are in the bottom basket (the top basket could have been moved inadvertently to the lower level).
Hope this gives you a starting point for checks.
ps bottom door seal is quite tricky to replace, so you may need to get an expert is the above tests indicate that that is the leak source.
Jul 11, 2010 | Bosch Dishwashers
Water left in bottom dishwasher and after resetting to wash will not start unless the water is drained out manually
GE Dishwashers are equipped with an anti-syphon ball that generally dislodges itself and goes into the drain line. To remove it, you'll have to pull it out of it's hole. Turn the supply off and open the kick plate. Remove the supply line from the dishwasher and the drain line free from the air gap. Remove the two screws that hold it to the counter top and pull it out. Remove the lower rack and spray arm. To remove the spary arm you have a 1/4 inch head screw to undo, and on the back of the spary arm is a plastic clip. Use a small screwdriver to depress from the spray arm and pull the spray arm off. There are then two 1/4 inch screws that hold the food screen on and remove the basket. Now, underneath the dishwasher is a large manilla-colored hose with a large hose clamp that must be loosened. Pull this loose and a bit of water as well as the ball will come out. Reattach and drop the ball into the left hole under the basket. Reconnect everything and slide the dishwasher back in. Reinstall drain hose and supply line. Turn on supply. Run and look for leaks.
Jul 11, 2009 | GE Dishwashers
Bottom spray arm not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Zanussi 21 in. DCE5655 Free-standing Dishwasher Logo
26 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
