Question about Whirlpool LER4634J Electric Dryer
MY LER4634PQO DRYER HAS STOPPED GETTING HEATED? FUSE BOX WAS CHECKED AND THAT WAS OKAY..WHAT COULD IT BE?
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside of the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time, by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Aug 24, 2010
I have an admiral electric dryer. It stopped in the middle of a cycle and the light is out and it won't turn on. I checked the fuse box, the plug and the belt is still on, so what do I do now?
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Jan 25, 2012 | Admiral Dryers
My ler4634pqo dryer has no heat. I have taken the back panel off but do not know how to locate the fuse.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 26, 2011 | Whirlpool Dryers
9 yr old Whirlpool Electric dryer has stopped and when you press the button to turn it on nothing happens. Checked fuse box and everything is okay there.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 01, 2011 | Dryers
Checked fuse box, good, checked plug in, good, door shut, good, dryer won't start, was in middle of drying load, stopped. Won't start.
may be door switch, here is a website that will help, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Kenmore 69101 Dryer
Dryer was working the just stopped and won't start back
check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Sep 13, 2009 | Amana NED5400TQ Electric Dryer
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer won't come on. it is plugged in and the outlet and breaker checked out ok.
are you getting voltage when you say you checked outlet? is it a gas or electric dryer? should have 220 or so at dryer for electric and 120 for gas. if voltage ok, trace it through to fuse most likely. no light in dryer means no voltage...
May 24, 2009 | Dryers
Saturn VUE 2004-Heated seats just stopped working. Fuse is fine..
This is not un- common. The heating elements do wear after a while. It is probably an open circuit in one of the pads in your seat. A quick restance check can determine which one it is.
Jan 02, 2009 | 2005 Saturn VUE
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
89 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
