Question about Video Game Consoles & Games
Only first screen of three hands appear and stop there
    Genius:
  • 1,234 Answers
If There's A CD In Your PSP
pick it off and reboot your console
Posted on Aug 26, 2010
How to set for 24 hrs.
Dec 29, 2015 | Watches
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
Jul 21, 2011 | Pulsar Chronograph Watch
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
When my daughter touches any object with the pen nothing happens. It will keep telling you to touch a picture on the screen with your pen.
You need to recalibrate. Try pushing B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take a few tries to get it to recalibrate correctly.
Jan 05, 2011 | LeapFrog LeapSter L-Max Console
I have a tomtom xl 330-s and cannot get a screen in english
To change the language to English on this unit do the following
1) First make sure the unit is fully charged as you will need to proceed with a reset of the unit.
2) Once the unit is fully charged - press and hold the on/off button for at least 15 seconds until you see it perform a restart.
3) Once you are sure it has restarted turn the unit on normally and you will see a screen filled with text. This will probably not be in English so tap the little tab in the right hand lower corner of the screen to proceed.
4) Now tap anywhere near the centre of the screen which brings you to a main menu.
5) You will see 6 icons on this screen. Tap the one right in the centre of the bottom row.
6) Now Tap on the right arrow icon (which is on the righthand bottom of the screen) until you see a screen appear with an icon with three flags. The three flags icon will be in the top left hand side of the screen.
7) Tap the three flags icon - you will see English appear in the options list - tap this and chose Yes to confirm.
If you follow this procedure exactly the unit will display English language screens from here on in.
Hope this helps. Many thanks for using FixYa.
Dec 29, 2009 | Tomtom XL 330S GPS Receiver
White line on screen easynote mv35-202
Replace the LCD screen. Its problem with the LCD panel.
Sep 07, 2009 | Computers & Internet
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
