Question about Epson Stylus NX400 InkJet Printer
I have nx400 and i put the ink and the printer say no reconace I'm sorry my ingles is not good but I spk spanish thanks
  • 724 Answers
What made u change the cartridge to begin with
Posted on Aug 24, 2010
How do I change the language on the screen of my printer. It is currently in Spanish.
Scan through its setting-menus, looking for 'idioma' or 'linguistico'
(the Spanish equivalent to "language").
Select that option, and change the language to 'ingles'.
Nov 26, 2010 | HP LaserJet 3050 All-In-One Printer
My epson NX400 is telling me I need ink but not telling me which color ink I need? How can I get to give me the cartridge color?
Open the top cove and look at the ink cartridges.
Usually the ink cartridge that needs attention will be blinking.
Oct 15, 2010 | Epson Stylus NX400 InkJet Printer
I've never change the ink cartridge before.
Usually you can find that the top of the printer can be lifted open. You will then see the three ink cartridges. remove each cartridge and see how low the ink level is if there's a centimeter or more it should not need changing. However some brands will force you to replace them all. or it won't accept that you have followed the directions.
Good luck,
Jim Hart
Jun 20, 2010 | Epson Stylus NX400 InkJet Printer
How do you replace and ink cartridge in the epson nx400
This link will give you a PDF file with instructions and images on how to replace ink cartridges in the Epson NX400:
http://files.support.epson.com/pdf/nx400_/nx400_bb.pdf
Jun 03, 2010 | Epson Stylus NX400 InkJet Printer
Dont know where to put the ink?thanks
i find that ink refills give a low quality print, and a4re liable to clog up the print head. You are much better advised to use re-manufactured cartridges. I use www.choicestationery.com for all of my epson ink requirements and don't have any problems with them at all. Hope this helps.
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
How do you take out the ink box out of a Epson Stylus NX400 printer?
Usually there is a clip that releases the ink cartridges. You have to lift up the scanner unit and the ink cartridge will move to a position where you can remove it. There you will see the clip that holds the cartridges in place. Pull it back and lift up. You will now be able to remove whichever cartridge you want.
If you are replacing the ink, insert it and press gently until it clicks and then push the clip back into place.
Close the scanner unit and you are finished.
Thank you
Lolita
Jan 18, 2010 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
I am looking for ink cartridges of Epson stylus nx400,
Here is a link to dealers in the Philippines that handle supplies:
http://www.epson.com.ph/support/dealers.shtml
Thanks for using Fixya.
Also, here is the main Philippines support page for future reference:
http://www.epson.com.ph/index.shtml
Jun 17, 2009 | Epson Stylus NX400 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Just installed Epson NX400 printer. Keep getting M88/69 "Cannot recognize ink cartridges" error. Tried re-inserting cartidges twice already and still same error. What next?
I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
FYI. I just bought NX400 last Friday. The error message came on this morning.
Jan 01, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
