Question about Dryers
If the heating element turns on and off is that the problem?
From what you say it could be the the thermal cut out caused by over heating and then comes back on after it cools down . This could be caused by the build up of lint that is causing the appliance to over heat. Check the units exhaust for build up as this is a common problem . Hope this helps .Harry
Posted on Aug 24, 2010
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Should the heating element on my oven be entirely red ? 80 % turns red right now.
it sounds like the heating element you bought is damaged or burnt out.
return it for an exchange
May 03, 2012 | Jenn-Air Ovens
How do you replace the bottom heating element
Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 09, 2011 | Ovens
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
I hav e an ADG7450.It will wash at 40 or 50 degrees but not at higher temperatures.Why?
Hi
Thanks
Daniel
Aug 20, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
Element light staying on
sometimes this is a wireing problem....elements will heat but do they turn orange. if not then the stove may be hooked up like a 110volts..
Nov 04, 2009 | Office Equipment & Supplies
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Oven won't heat up
Ok, this is a definite element malfunction. you can confirm this by using a multimeter and connecting the meter to the terminal points on the element. once connected, turn on the heating cycle and if you can register a reading and the element dosen't light or produce any heat, this will confirm element failure and you will need to replace it.
Please rate and god bless:)
Apr 20, 2009 | Ovens
Dryers Logo
32 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
