Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have a cabrio top loader washer and I'm getting a LF error message
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
What does whirlpool duet error code lf?
Lf or long fill could be a multitude of many. Is the water turned on, is the hoses kinked , the water inlet screen clogged, water lines crossed, bad or faulty water inlet valve, or faulty pressure switch.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
What does LT mean on a washer
LT is not an error.
Perhaps LF?
CLICK HERE for the error code list.
Thanks!!
Feb 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool Cabrio, what does LF error code mean and how do i fix it??
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't agitate on wash ?-on lf sign
if LF error code its long fill. control did not detect water entering/ no change at pressure sw. check pressure switch /hose. blockage in hose likely.
Mar 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirpool cabrio top load washer 1.5yrs old flashes FXX error code
Try this:
  1. Switch off the power using the 'MAINS ON/OFF' button
  2. Press and hold the 'Temperature' button
  3. Carry out the next three steps within 3 seconds;
  4. Switch on the power
  5. Release the 'Temperature' button
  6. Press the 'Soil type' button
  7. Check that a message similar to "DIAGNOSTIC MODE 123F7F2F5V127" is displayed. If it is not, repeat from the beginning
  8. Switch off the power
  9. Switch on the power. The fault code should have cleared.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
LF error on my washer
Have you checked the filter screens at the washer inlet valves?
If the hot and cold water supply to the machine is good, and the filter screens on the washer inlet valves are clear..Then the inlet valves have failed and will have to be replaced.
Jun 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
