Question about Poulan Pro 22" Self Propelled High Wheel Mower
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
  • 183 Answers
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Posted on Aug 23, 2010
How do I remove the blade adapter from a Poulan Pro 22" self propelled mower
The blade adapter is a "slip fit" on the crankshaft and is held on by the blade retaining bolt. However, due to rust, etc. they can become difficult to remove. You may try penetrating oil to help loosen the rust.
We generally use an air tool to remove stubborn adapters but you have to exercise caution so as not to put undo stress on the crankshaft. In some rare instances they have to be "cut off".
Feb 20, 2011 | Poulan Pro 22" Self Propelled High Wheel...
How to change oil in poulan 22 self-propelled mower
there should be a drain plug under the mower near the shaft that the blade is connected to... good luck
Apr 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
I have a Poulan Pro self propelled lawn mower. Was running and just stopped. Did not hit anything. Can not start and have replaced the spark plug but do not get a spark. Is it the magneto and how do I...
i had the same problem. the coil is located under the "hood" if you may, just take that off and you should be able to get to it pretty easily,just unscrew the coil and find one on ebay for just about $29 for a 2-4 hp
Jun 24, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
444 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
