Question about Sharp AR-M350U Copier
I need drivers for the sharp ar-m350u copier where can i obtain them
  • 61 Answers
Http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx Yyou can search for your operating system, most vista drivers work with Windows 7
Posted on Aug 23, 2010
  • Chad Kliever Aug 23, 2010
    I forgot that in your search the ARM350U drivers are ARM350N drivers.
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Sharp AR-M350U Copier/Printer Error Code F2-00
clean developer unit connector .pull out , clean , then insert .
May 25, 2010 | Sharp AR-M350U Copier
I have a problem with a AR-M350U. Bottom half of
charge ?
also drum earth could be a factor.
Feb 08, 2010 | Sharp AR-M350U Copier
IS IT SAFE THE RADIATION OF SHARP AR-M35OU+
I am assuming you mean laser radiation from the laser unit that the copier uses to write the images on the drum. if correct, normally when front door cover is open the laser unit is disabled and no laser radiation is present and therefore it is safe.
Dec 18, 2009 | Sharp AR-M350U Copier
AR-M350U L6-01
If you mean L6-10, that is a Laser Unit Malfunction. Lucky for you, the LSU are pretty cheap for this machine.
Nov 03, 2009 | Sharp AR-M350U Copier
Scanner on Sharp AR-M350u is showing NG800000 and is not sending scanned items.
This mistake NG800000 offset scanning device.
1 Try reinstall a driver on local on cord USB
2 Remove glass of the scanner and check displacement scanning device, it must softly move. Smazhte nodes mask, продуйте the sensors, check join a wire. Do Not use the long cord USB gets lost the signal, appear the hindrances.
Write, help. Good luck
Jun 22, 2009 | Sharp AR-M350U Copier
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
Sharp AR-M350U Copier Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
