Question about Acer Aspire One PC Notebook
I accidently dropped my sister's laptop and am currently trying to fix it. It's a Aspire one acer notebook laptop. I'm a complete noob when it comes to computers so please help me. When I press the power button this is what I get: "Intel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key" What does any of this mean and what should I do?
    Sergeant:
  • 238 Answers
Laptop's inside connection might gone loose or disconnected. As your laptop is not getting any bootable device, it means your laptop not detecting the hard drive. If you are new then better not to open the laptop. my advice is to take it to a service center or to a service engieer. it will not cost you much and its safe.
Posted on Aug 23, 2010
  • Acer Master
  • 5,423 Answers
The computer is trying to boot from a server (Local Area Network) since it has lost the OS on the hard drive. Possibly the cable between the drive and the motherboard was damaged. Alternatively, the hard drive was damaged - at minimum it lost the Master Boot Record which told the computer where to find the operating system. Frequently you can access the BIOS information to change the boot order by pressing F1, Esc or F2 before the computer attempts to load the OS. On many systems you can change the boot order for one time access by pressing F12 at this same point.
I believe this computer doesn't have an internal optical drive, so an external drive will be needed to repair the unit.
Recovering the data first probably will require taking the drive out and using another computer with a SATA to USB drive connector or a 2.5" drive enclosure.
If you have an optical drive, you can use the OS install or upgrade disc to do a recovery of the drive. Make sure to match the service pack version for Windows. (Any LiveCD (anti-virus or Linux) will let you check if the drive is connected and visible.) Some Unix versions can be run from a USB flash drive.
I hope this helps.
  • 846 Answers
it means it can't find a boot device. your hard drive either popped loose or is broken. would assume somebody has to open the Laptop and re-attach the part. If you want to pay to have somebody do it for you there is a third party Acer Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Acer Repair guide. Maybe a tech savy friend can do it for you.
Posted on Jan 20, 2011
I dropped my acer ASPIRE 5336-2524 laptop. Now the screen is distorted. I tried to get into display properties, then re-installed Windows 7. However, I can only identify one-third of the computer screen. I...
If you dropped your laptop and the screen got broken, there is no way to fix it via any software change. But you have two options:
  1. Connect an external monitor via VGA port, more information here
  2. Get fixed it by Acer service
Jul 06, 2011 | Acer Aspire 53362752 Notebook
Acer aspire 4810T was drop on the floor i think the lcd broked..how much its lcd cost?
A minimum of $350.00 plus labor, depending on where you live. You can try and buy a used "for parts" notebook just like yours on eBay and pay someone to replace the monitor. That will be much cheaper if you don't have an accident insurance on your notebook.
Jun 09, 2010 | Acer Aspire 3680 Laptop
Acer aspire 5315
well i think you are asking for to use your dell cd to install in your sister's laptop.maybe it will not work because they are specific system configured .you can't use them everywhere.
Mar 31, 2010 | Acer Aspire 5315 Notebook
My laptop acer aspire 1640z wont let me disfragment or update windows or restore is there any way to factory reset wiv out disks
you got bugs or trojan inside your system, remove that virus to run normally, use NOOB KILLER software
Jun 16, 2009 | Acer Aspire 1640Z Notebook
Blank screen...no keys working
You broke it! Try re-installing OS software, hoping you still have the CD disk.
May 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Webcame
use yawcam.com/
or call 0845 20 20 118 for remote help
Dec 14, 2008 | Acer Aspire 3610 Notebook
Colour distorted after laptop fell
its better you should take it to the technician, i think the cable that gives signal to the panel has become faulty
Nov 24, 2008 | Acer Aspire 5610 Notebook
Acer Aspire 5050 Power ON problems
that maybe the only problem. lets hope so.
Jul 29, 2008 | Acer Aspire 5050-3242 Notebook
LCD INVERTER
FYI,
If your lcd is cracked, your warranty is gone. It doesn't matter if it is accident or not, because it is user fault. Unless you have 3 year total warranty from acer, they will repair it.
Apr 22, 2008 | Acer Aspire 5100 Notebook
Hybernation?? HELP!
hey, its kinda hard to tell exactly without seeing the laptop, but if you could try this, its a common problem with alot of laptop batterys.
remove the battery from the laptop, usually a switch on the bottom of laptop to remove the battery.
and try running the laptop off the mains without the battery in,
alot of the time that can fix the problem if its a faulty battery.
let me know how you get on,
John
Jan 02, 2008 | Acer Aspire 3502WLCi Notebook
Acer Aspire One  PC Notebook Logo
661 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
