Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Can you please tell me how I can acquire the wlan key for this type of router.
    Sniper:
  • 58 Answers
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and then 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID, WEP/WPA key for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
  • 77 Answers
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
Posted on May 04, 2008
HOW TO FORWARD PORTS 8090 AND 37766 TO SPECIFIC IP ADDRESS
Go to this web site and follow the instructions.
These instructions are specifically for your router and a host of different apps you can forward the ports for
http://portforward.com/english/routers/port_forwarding/Netopia/2247NWG-VGx/2247NWG-VGxindex.htm
Jan 18, 2011 | Netopia 2247NWG-VGx Wireless Router...
HOW TO set up PORTFORWARDING ON NEOTOPIA 2247
Since your router is Netopia 2247NWG-VGX follow this on line guide, choose the application you need to forward to and make all the settings you need.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
I need the dns server address for netopia 2247nwg-eir
Connect pc to the the router using ethernet cable. Go to "Run". Type "cmd" (command prompt). In the command prompt, type ipconfig /all then enter. On this point, information in your connection will seen. see picture below.
Mar 28, 2010 | Netopia 2247NWG-VGx Wireless Router...
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
My router will not communicate with my laptop wirelessly. It works fine by cable just over wi fi it won't work
You might have missed to type your network key. Connect to the wireless network again and make sure to type in the correct wireless network key
Jun 20, 2009 | Netopia 2247NWG-VGx Wireless Router...
How do i get my wireless key so i can set up my laptop
Just access the router's setup page of the router using your wired computer. Open your internet explorer and type http://192.168.1.1
Jun 09, 2009 | Netopia 2247NWG-VGx Wireless Router...
Xboxlive on netopia 2247nwg
Have you tried http://portforward.com/ i've had alot of problems with this router fixed my xboxlive issues with portfoward but am having problems with my blueface voip
Feb 26, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
765 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
