The washing mashine will not drain and does not spin
  • 240 Answers
Top load? check lid switch. on front load if it does not drain then it will not spin but will give error code for something like long drain. check drain pump. ge top loader has separate drain pump.
Posted on May 04, 2008
    Problem Solver:
  • 10 Answers
GO TO A APPLIANCE SHOP GET A MOTOR THEIR ABOUT20 TO 30 DOLLARS THEIR REAL EASYTAKE ABOUT10 MIN TO DOIT TO PUT IN IF ANY THING WRITE ME BACK
/Hello How do I wash a cloth and let drain the wahter and again prigramm the washingmashin to wash that cloth again
your nuts
a washing machine performs a cycle
wash rinse and spin
and thats that
you need a woman or man to wash again and again
Feb 07, 2015 | Washing Machines
My washing mashine won't drain or spin
Your machine won't drain without spinning so I am relatively sure that you drive belt snapped. Pretty easy to replace once you take the back off of the machine.
Jun 01, 2014 | Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
PUMP REPLACEMENT
Possible that the hose link to the drain is loose, the drain pump is defective and leaking or the rubber door gasket is faulty. Please take a good view
May 02, 2013 | EuroTech Washing Machines
Hello, My washing machine MW 6152W instuction guide can't find it and my washing machine is now on but doesn't spin at all for nearly 8 hours now. Please help me to get my washing mashine work.
hello check the pump first it has drain water out first before it spins if the pump is ok then check the module board this controls the motor speed if this ok the brushes on the motor can cause it not to spin hope it helps
regards
shaun
Mar 20, 2011 | Washing Machines
My washing mashine wont spin or drain
hi there,
it sounds like the drain is blocked, check the drain access at the front
for any debris/or coins that may have been left in the pockets of garments, have a good rake around and use a torch, the machine will not spin without pumping out the surplus water so there lies your problem blocked tubes or a faulty water pump.
Feb 15, 2010 | Indesit W 123 Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
My washing mashin shows F35; First shows sud
Check the drain line for kinks or obstructions first. Then check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check for anything clogging the pump and inspect the pump impeller for broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully, it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
