Question about Playmobil Coast Guard Boat
Boat only goes in reverse. how can we get it to go forward?
    New Friend:
Turn the battery around.
Posted on Dec 24, 2012
3 Suggested Answers
  • 5681 Answers
SOURCE: 79 charger boat goes in reverse but not forward
Try disconnecting the throttle cable and then operate the shift lever. You either have the two cables reversed or the gas side is too far one way and it is throwing you out of range for the shift.
The cables come to a fulcrum point in the shifter box. If one of the ends on the motor side is too far in one direction, the other cable can not travel. Even after disconnecting from the carb you may have to screw the connector to allow more travel in the gas cable so the shift works.
Good Luck
Posted on Jul 17, 2009
SOURCE: my boat goes in backwards
My guess is you have the wrong prop on your boat. You need to check if it is a right or left prop. Right hand prop will spin clockwise if you are looking at it from the rear.
Posted on Sep 04, 2011
I have a Donzi boat with a mercruiser alpha 1 drive and a 5.7 liter engine There is a wire coming from the distributor to a closed contact on the forward and reverse cables at the motor what is this
This wire actually KILLS the ignition for a short period while shifting into reverse. The thought was to lengthen the life of the clutch dog and reverse gear, especially during "abusive" shifts into reverse from a high speed forward position. Most folks never realize it's there, and usually requires no maintenance or attention!
Sep 17, 2017 | Boating
I got my propeller replaced. I took my wave runner out for the first time and the engine Reves but there is no forward movement
Check if the reverse cap goes up and down. For forward movement it should be totlly up, freeing the waterjet tube.
For neutral, the cap should be about half way.
For reverse it should be donw, covering totally the waterjet tube.
Aug 20, 2017 | Boating
My honda 40 hp boat motor the alarm goes off when the key is on when t put it in reverse or forward I unhooked the linkage and when i hooked it up the alarm goes off
It's normal if you remove the cable harness, the alarm goes off.
Check your engine oil level.
Disconnect the engine temperature sender. If it then stops sounding, replace the sender.
Does the alarm still sounds when the engine is running?
Does the engine has had his maintenance?
Maybe you can post the exact engine type, so we can look for the exact alarms wiring system...
Jul 30, 2017 | Honda Boating
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
My boat goes in backwards when i put it in gear and when i put it in reverse it goes forward. what could be the problem?
Sep 12, 2010 | Kitchen Ranges
Mercury 115 problems
This could me that reverse gear is not fully engaged.Adjustment on the cables is needed.Take the cowlings off.With the motor not running,move the throttle/gear selector into forward and reverse.You will see where the cables move in the engine area.Note which way the cable moves the selector when reverse is selected.Do this next bit from inside the boat.Hook up the flusher to the motor and start it.Select reverse.When you hear the grinding,push the selector by hand in the direction of travel.It should engage the gear fully.You will see the adjustment threads on the control cables.Move to suit.Hope this helps
Jul 28, 2009 | Boating
Good Luck
Jul 13, 2009 | Boating
Playmobil Coast Guard Boat Logo
601 people viewed this question
Top Playmobil Toys Experts
thegtw
Tom Chichester
Are you a Playmobil Toy Expert? Answer questions, earn points and help others
