Question about HP Pavilion dv6000z Notebook
Hi my HP G6000 laptop wont turn on, when i press the power button on the lights flicker for a second and then nothing
    Sergeant:
  • 238 Answers
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD is faulty and need to replace.
Posted on Aug 23, 2010
My laptop hp g6000 will not start up when I press the power button
Remove then replace battery. try again. If on the external power supply press and hold the power button down for several seconds. Now remove the battery and disconnect the power plug. I f this still doesn't fix the problem, the man board may be bad. It is a known issue with this model. Good Luck.
Apr 10, 2014 | HP Computers & Internet
Replaced motherboard on hp g6000 .the blue power light comes on ,but power button will not turn laptop on
is the ribbon cable damaged at all?did u install it correctly?
pull it out and put it back in and lock it in place i think by pressing down the lil tab
Oct 30, 2010 | HP Power button/LED board kit with LED...
No display on hp 6345s laptop
Try to turn off your system. Then remove the cables and battery on the laptop. Then press and hold the power button for 8 secs. Then, reinsert the cables and battery on the laptop. Then, press the power button to turn on the laptop. If the HDD light flickers continuously, then the problem is on the Hard Drive. One way of resolving it is to Re-Seat the Hard Drive. If you know how to tear down the system, here's how. Turn off the laptop, remove the cables and battery at the back. Remove the screws located at the corners of it. Then remove and reinsert back the Hard Drive. If it still fails, contact ACER to immediately replace the Hard Drive. If you don't know how to tear down the laptop, then call ACER also for repair....
Jul 19, 2010 | Acer Aspire 9300 Notebook
Hi
The problem is from either the battery or the adapter .This is how to know;
First remove the battery of your laptop,plug the adapter,connect to electricity and put it on If the laptop turns on, then the battery is faulty and should be changed
If it doesn't come on,test it with another adapter. If it comes on then the adapter is faulty and you should get a new one
Cheers!!
Mar 03, 2010 | HP Pavilion dv6000z Notebook
HP G6000 laptop wont start
Extract your battery from your laptop for 12 min, then start your computer using your power cable (don't use your battery), if not try pressing F2 rapidly when opening, after you open your operating system try changing your graphics card drivers.
Jan 31, 2010 | HP Pavilion dv6000z Notebook
My hp notebook just shut off,wont come back on
Sounds like a burnt out capacitor. Either on motherboard or power supply.
You can try taking out battery, press and hold power button for 5 seconds, put back in and try to turn on. If it doesn't turn on, then I'm afraid motherboard is bad or memory card is faulty
Nov 11, 2009 | HP Pavilion dv2610us Notebook
HP Pavilion dv6000z Notebook Logo
251 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
