How to unlock region code for philips dvp3142 after updating last firmware in november 5th 2007 ?
4 Suggested Answers
Beignorant
  • 51 Answers
SOURCE: I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
or
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Posted on Mar 30, 2009
  • 189 Answers
SOURCE: unlocking a Philips 3142
HELLO!
I think you will find this useful!
Switch on the player Then open the disc tray
Press 9879 and the region code number you want to set the player to.
Hope this helps you! (:-).
Posted on Aug 20, 2009
muntejaya
  • 10421 Answers
SOURCE: I need to unlock the region code on a philips dvd
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_er4e3
Posted on Feb 27, 2011
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
I bought some DVDs at amazon.com, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Regards,
BElectric.
Jan 28, 2011 | Philips Televison & Video
I can't play dvds but I can play copied dvds
Most copied DVD-Videos for home playback use a CSS crack to strip the region code i.e. to Region 0 to they will work in all DVD players.
However most standalone DVD Players can have this restriction lifted using a sequence of codes.
First check your current firmware version to see if you need to upgrade:
1. When TV shows Philips wallpaper, close disc tray with no disc.
2. Press <0>, <0>, <0>, <9>, <OK> on the Remote Control.
Note: In case the firmware version does not appear on the screen, eject and close the disc tray to reset, and try again.
In this case region is 2 (UK) and the firmware is “Feb 23 2007” this is the latest for this DVD VR.
There are other codes that can be used to set this DVD to region 0 it might be a good idea for you do to the same with yours.
Nov 22, 2009 | Philips DVDR3380/05 DVD Recorder
Mwd2205 firmware update
icon_minipost.gifRegion code hack posted by Bob, July 28 2007:
The 2205 and 2206 are not made by MAGNAVOX.
The manufacturer is FUNAI CORP.
Note: This hack is incomplete because of lack of firmware available for the drive. If anyone can provide the firmware please provide a link!
1. Press 1,2,3,4 and the Display buttons on your remote to see your...
Model Number: E8C60UD "May Differ in Products!"
Firmware Revision: 1.24 "May Differ!"
Region Setting: 1 "We want 0 for Multi-Region!"
2. Press 9,8,7,6 and the Search Mode buttons on your remote to initiate the firmware upgrade sequence.
"When firmware is found or released for this model, the user burns it onto a cd, inserts the disc in the tray and the machine will update itself for about 5 minutes. The user then uplugs the machine, replugs and the process is complete. Perform step 1 again to ensure you are Multi-Region compatible."
Oct 16, 2009 | Philips Magnavox DVD/VCR Dual Player
Unlocking a Philips 3142
HELLO!
Aug 20, 2009 | Philips DVP3040 DVD Player
How to unlock code to make my LG BD-390 region free. I am trying to play a dvd I bought in Italy 3 years ago.
Ha.... Found the soultion.
The fix is the same as fr LG 5931.
I.e. download a small file and burnit with e.g. ultraiso on a DVD-R.
Boot yr LG BD370 or 390 with the DVD in the reader - it will flicker some numbers on the Display and then say Region 0.
You get the file here:
http://www.multi-region.net/lg
Worked like a charm :)
Jun 10, 2009 | Sharp DVRW250 DVD Players
or
1. Press "Eject"
2. Press "Setup"
5. Press 1, 3, 7, 9
7. Press "Play"
Mar 29, 2009 | Yamada DVD-5520 DVD Player
Unlocking code for Philips HTS 3500s DVD
Eject disc. While open press 99990. Thats it.
Jan 24, 2008 | Philips HTS3500S System
REGARDING UNLOCKING OF DVP 3028 REGION CODE C1
1st: Start the DVD player, make sure there is no CD/DVD inside.
2nd: Bring up the System Menu.
3rd: Go to Preferences, press 138931.
4th: Use the Up/Down arrow keys to select the region 0 .
5th: Exit the screen.
You can now play DVDs of any region. Enjoy!
Dec 01, 2007 | Samsung Blackjack SGH-I607 Smartphone
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
Electro Med Services...
