Question about LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium
Water is dripping into the bottom under the freezer storage bin. It then freezers, and forms a sheet of ice under the bin. What is causing this!!!
  • 2 more comments
  • beebee3 Aug 23, 2010
    Hello and thank you
    But I forgot to include that the actual model of my refrigerator is the LRFD25850TT
    does this model have a different solution.
    Ok how am I to know which part it is or is this beyond average handyman fix, Can these parts be purchased a the average appliance parts store>
    Can I do it myself?
    Refrigerator Model Number LG French door, LRFD25850TT
    is the model that I have leaking water from the bottom freezer door, water is collecting in the bottom and freeezing under the food storage bin
  • beebee3 Aug 24, 2010
    is the model that I have leaking water from the bottom freezer door, water is collecting in the bottom and freezing under the food storage bin.
    WHERE IS THE DRAIN TO THE DRIP TRAY, I NEED TO SEE I ITS CLOGGED...HELP
  • LG Master
  • 3,247 Answers
There should be a drain hole at the bottom of the freezer compartment which removes any condensate as part of the auto defrost. However, if this hole is blocked it could be causing the condensate to collect at the freezer base and ice up.
Turn off the power to the fridge. Take out the drawer from the freezer. Get a hair dryer and run it at the back edge of the freezer compartment. Once the ice melts you will expose the hole. Remove the block (could be frozen pea). This should hopefully fix the problem.
Also provide me the actual model no. of your fridge so that I can check other possibilities. Does this come with an ice maker?
Posted on Aug 24, 2010
  • Sam Aug 24, 2010
    I just found out the model no. of your fridge. Sometimes fixya system does not show all the information the customer provides.
    Looking at the model you have, it can be difficult to pinpoint the source of the water. It is likely the water tube that supplies water to ice maker is frozen with ice. This could be leading to water leaking and overflowing into the freezer base. Test with the water inlet shut if you can do it. If the water is still coming then it must be a blockage in the base and can be fixed as I mentioned in my earlier post.
    If not then the ice is in the water inlet tube to the ice maker.
    To fix this shut the power (after taking the items out of the fridge) and letting the whole freezer reach room temperature. Dry the freezer thoroughly and turn the power on. Put the food items back in and wait to see if the problem reappears. If problem has not gone away then you need a technician to fix the freezer compartment. You can get an idea of the parts involved from this site. Click on each schematic to view the parts.
    Hello cmmiuser01
    I have disconnected the water supply and shut off the icemaker for over a month now. so there is no water coming into the frig only water is being defrosted, i guess?
    I don't see a drain hole in the bottom of the freezer compartment, is there an actual hole that is visible? Ive looked at the schematic and don't see it...
    the only tube that I have seen has been in the back of the frig on the bottm right, above what I think is called the defrost tray?!...
    if I can find the hole from where the water is dripping I can go forward from there.
  • 3,083 Answers
It sounds like the drain hole is clogged or frozen up. Here is a web blog about this problem, and how to fix it:
http://askville.amazon.com/GE-side-by-side-fridge-water-leaking-freezer-coming/AnswerViewer.do?requestId=10037938
Good luck, thanks for using FixYa, and hope this helps!
Posted on Aug 23, 2010
    President:
  • 2,559 Answers
First remove the drawer and make sure the drain is clear,(you will see the hole in the bottom on a little shelf area) If drain is clear and problem still happens,You have an issue with the defrost cycle and will need one of 2 parts replace, 1 is the defrost thermostat and the other would be the defrost board/Timer
  • 3 more comments
  • Randy Hough
    Randy Hough Aug 23, 2010
    No,The model doesn't matter in this case. The solution is the same.
  • Randy Hough
    First make sure the drain is clear, Then if it is clear and you need to replace parts, It is harder than the average handyman type job but instructions that come with the parts will determine if you want to do it yourself
  • Randy Hough
  • Randy Hough
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Ice maker sprays water into the ice storage bin
you need to remove the i/m from the freezer and make sure the "fill cup" doesnt have an ice blockage. thats where the water has to funnel into the mold. it can get a drip into the cup and then freeze in the cup. clear it out once and try it again, but if it happens once or twice again , then you might have to replace the water inlet valve.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
LG 24.7 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Titanium Logo
219 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
