We have Envox 6.3 HF7 with HMP 3.0 SU 267. It was working and all of the sudden it stopped working.we hav e 4 fax resources. here is how the fax gets generated. -a call comes in and requests a fax, a record gets inserted into a table. a 30 minutes timer keeps checking to see if there is any fax needs to be processed, if yes, it goes and reserve the resource and tries to send it, once it tries to send it, the system throws an error saying no fax resource available. any ideas? thanks
  • rami_hachem Sep 08, 2010
    Thanks for your reponose,
    it is not even leaving the server, i'm seeing errors on the server itself that there is no fax resources eventhough i have fax resources. i confirmed it on the HMP side through HMP license Mananger.
    Brigadier General:
  • 3,513 Answers
Hi
Something must have happened to the network that is dropping your reception out of the sweetspot. Neither fax machine is to blame.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
HOW DO I CHANGE THE FAX NUMBER ON MY BROTHER INTELL FAX2820
1. Press "Menu/Set" key
2. Then press "0" (zero) key
3. Press "3" key
4. You will see on display "Station ID"
5. Press "Menu/Set" key
6. Press "1" key to change fax number
7. Then when you enter new number press "Menu/Set" key, then "Stop/Exit"
that is it
Jan 31, 2011 | Brother IntelliFax-2820 Laser Fax
What is the order of connecting the wires of the ignition coil
You didn't post your engine size so please pick the correct one:
3.8L (VIN B and 3) Engines Firing Order: 1-6-5-4-3-2 Distributorless Ignition System
3.8L (VIN C, 1, L and K) Engines Firing Order: 1-6-5-4-3-2 Distributorless Ignition System
Buick-built 231, 252 V6Engine firing order: 1-6-5-4-3-2Distributor rotation: Clockwise
Olds-built 260, 307, 350, 400, 403, 455 V8Pontiac-built 265, 301, 350, 400, 455 V8Engine Firing Order: 1-8-4-3-6-5-7-2Distributor rotation: Counter-clockwise
Buick-built 350 V8Firing order: 1-8-4-3-6-5-7-2Distributor rotation: Clockwise
Chevrolet-built 267, 305, 350 V8Firing Order: 1-8-4-3-6-5-7-2Distributor rotation: clockwise
Chevrolet-built 262Firing order: 1-6-5-4-3-2Distributor rotation: clockwise
Aug 07, 2010 | 1988 Buick LeSabre
Need fire order,spark plug wires replaced in incorrect place
For several engines....
Fig. 1: Buick-built 231, 252 V6 Engine firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
Fig. 2: Olds-built 260, 307, 350, 400, 403, 455 Pontiac-built 265, 301, 350, 400, 455 V8 Engine Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: Counter-clockwise
Fig. 3: Buick-built 350 V8 Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Fig. 4: Chevrolet-built 267, 305, 350 Firing Order: 1-8-4-3-6-5-7-2 Distributor rotation: clockwise
Fig. 5: Chevrolet-built 262 Firing order: 1-6-5-4-3-2 Distributor rotation: clockwise
Hope helped with this (remember rated this help) Good luck.
Nov 05, 2009 | 1985 Oldsmobile Delta 88
Nero Photosnap Viewer Suddenly stopped working.
Let's say you cannot open JPG pics. This is what you have to do. 1) In explorer (My Computer), click Tools > Folder Options. 2) In the dialog box, click 'File Types' tab. 3) Scroll down until you see the JPG extension. 4) Select it and click 'Change' button below. 5) Select a program you want to use to open JPG files. (Windows Picture and Fax Viewer is the default program: You can select it.) 6) Click OK button. 7) If you have trouble opening other graphic types (BMP, GIF, PNG etc.) look for those extensions and repeat steps 4 to 6. 8) Click 'OK' button to close Folder Options dialog.
Jul 21, 2009 | Computers & Internet
How to be solve banker algorithm?example
I m providing you this from my college notes
Banker's Algorithm
* multiple instances of resource types IMPLIES cannot use resource-allocation graph
* banks do not allocate cash unless they can satisfy customer needs when a new process enters the system
* declare in advance maximum need for each resource type
* cannot exceed the total resources of that type
* later, processes make actual request for some resources
* if the the allocation leaves system in safe state grant the resources
* otherwise, suspend process until other processes release enough resources
Banker: Data Structures define MAXN 10 /* maximum number of processes */
#define MAXM 10 /* maximum number of resource types */
int Available[MAXM]; /* Available[j] = current # of unused resource j */
int Max[MAXN][MAXM]; /* Max[i][j] = max demand of i for resource j */
int Allocation[MAXN][MAXM]; /* Allocation[i][j] = i's current allocation of j*/
int Need[MAXN][MAXM]; /* Need[i][j] = i's potential for more j */
/* Need[i][j] = Max[i][j] - Allocation[i][j] */
Notation:
X <= Y iff X[i] <= Y[i] for all i
(0,3,2,1) is less than (1,7,3,2)
(1,7,3,2) is NOT less than (0,8,2,1)
Each row of Allocation and Need are vectors: Allocation_i and Need_i
Banker: Example
Initially:
Available
A B C
10 5 7
Later Snapshot:
Max - Allocation = Need Available
A B C A B C A B C A B C
P0 7 5 3 0 1 0 7 4 3 3 3 2
P1 3 2 2 2 0 0 1 2 2
P2 9 0 2 3 0 2 6 0 0
P3 2 2 2 2 1 1 0 1 1
P4 4 3 3 0 0 2 4 3 1
Banker: Safety Algorithm
* consider some sequence of processes
* if the first process has Need less than Available
* it can run until done
* then release all of its allocated resources
* allocation is increased for next process
* if the second process has Need less than Available
* then all of the processes will be able to run eventually
* IMPLIES system is in a safe state
STEP 1: initialize
Work := Available;
for i = 1,2,...,n
Finish[i] = false
STEP 2: find i such that both
a. Finish[i] is false
b. Need_i <= Work
if no such i, goto STEP 4
STEP 3:
Work := Work + Allocation_i
Finish[i] = true
goto STEP 2
STEP 4:
if Finish[i] = true for all i, system is in safe state
Banker: Safety Example
Using the previous example, P1,P3,P4,P2,P0 satisfies criteria.
Max - Allocation = Need <= Work Available
P1 3 2 2 2 0 0 1 2 2 3 3 2 3 3 2
P3 2 2 2 2 1 1 0 1 1 5 3 2
P4 4 3 3 0 0 2 4 3 1 7 4 3
P2 9 0 2 3 0 2 6 0 0 7 4 5
P0 7 5 3 0 1 0 7 4 3 10 4 7
10 5 7<<< initial system
Banker: Resource-Request Algorithm
STEP 0: P_i makes Request_i for resources, say (1,0,2)
STEP 1: if Request_i <= Need_i
goto STEP 2
else ERROR
STEP 2: if Request_i <= Available
goto STEP 3
else suspend P_i
STEP 3: pretend to allocate requested resources
Available := Available - Request_i
Allocation_i := Allocation_i + Request_i;
Need_i := Need_i - Request_i
STEP 4: if pretend state is SAFE
then do a real allocation and P_i proceeds
else
restore the original state and suspend P_i
Banker: Resource-Request Algorithm [129]
Say P1 requests (1,0,2)
Compare to Need_1: (1,0,2) <= (1,2,2)
Compare to Available: (1,0,2) <= (3 3 2)
Pretend to allocate resources:
P0 7 5 3 0 1 0 7 4 3 2 3 0<<<
P1 3 2 2 3 0 2<<< 0 2 0<<<
Is this safe? Yes: P1, P3, P4, P0, P2
Can P4 get (3,3,0)? No, (3,3,0) > (2,3,0) Available
Can P0 get (0,2,0)? (0,2,0) < (2,3,0) Available
Pretend: Available goes to (2,1,0)
Thanks And Regards
May 13, 2009 | Microsoft Windows XP Professional
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Change phone number
Hi, Below are the instruction for that. You can find the full operators manual at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=fax2820_us_as&type2=8&flang=English&dlid=
Hope that helps...
Lbcoaster
You should store your name and fax number to be
printed on all fax pages that you send.
1 Press Menu/Set.
2 Press 0.
3 Press 3.
4 Enter your fax number (up to 20 digits) on
the dial pad, and then press Menu/Set.
5 Enter your telephone number (up to 20
digits) on the dial pad, and then press
Menu/Set.
(If your telephone number and fax number
are the same, enter the same number
again.)
6 Use the dial pad to enter your name (up to
20 characters), and then press Menu/Set.
7 Press Stop/Exit.
6 Set the Date and Time
Year:2007
Month:03
Day:01
Time:15:25
If you make a mistake, press Stop/Exit to
start from Step
1.
7 Set your Station ID
Fax:_
Tel:_
Refer to the following chart for entering
your name.
If you need to enter a character that is on
the same key as the previous character,
press to move the cursor to the right.
Press
key
One
time
Two
times
Three
times
Four
times
2 A B C 2
3 D E F 3
4 G H I 4
5 J K L 5
6 M N O 6
7 P Q R S
8 T U V 8
9 W X Y Z
For more details, see “Entering Text” in
Aug 01, 2008 | Brother IntelliFax-2820 Laser Fax
Fax Confirmations
1) Menu/set
2) 2
3) 4
4) 1
5) Press + or - "ON" or "ON+ IMAGE" to have confirmation with a preview image of the first oage you sent
6) Menu/Set
May 01, 2008 | Brother IntelliFAX 2800 Laser Fax
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
