Question about Dryers
My 500 plus seies Bosch dryer will not run on any selections it only makes a click sound when start button is pushed. What may be the problem/
  • 3 Answers
Unplug it, move it away from wall, remove two screws on the plastic tabs at the rear, pop off the top. If the belt (very thin rubber band) is around the middle of the drum, then the belt is prolly fine. This dryer has a sensor for broken belts. The sensor ALSO will trigger if someone like my dope-slap-teenager puts in a mess of soaking wet cloths (washer didn't spin right). The sensor is easily reset, but you have to remove the back panel to access it.
Posted on Oct 09, 2011
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
Dryer stopped in the middle of a cycle. Time kept going, drum and motor stopped. Unplugged dryer, check lint and exhaust hose for build up. Plugged dryer back in, when I select time and hit start, dryer...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Mar 12, 2011 | Bosch Nexxt 500 Dryer
I have a Bosch 500 plus model. I was drying a blanket by itself when the dryer just shut off. The blanket was in a ball. I spread it out and turned the dryer back on and it wouldn't start. No error codes...
Oct 30, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer does not start
Dryer Repair - The
Dryer Repair - The
heatman101
Jul 26, 2010 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Bosch Nexxt 500 Plus Dryer
The power goes on (lights up) and when I push start there is a click, but no movement. Can you help me?
wow, sorry. I shouldn't post til after more caffiene. I was thinking washer when I asked you those questions.
Now, the correct questions :) Have you tried on all cycles? When you press start does the display change at all? is the lint filter light on?
Apr 20, 2010 | Bosch Nexxt 500 Plus Dryer
Bosch dryer has pwr but not turning on
Sounds like the belt is broken or off of track.
Jun 03, 2009 | Bosch Nexxt 500 Plus Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
